Online Now [387]:
Visitors: 386
Today: 172976
Total: 155465763
Forums › The Car › 206 Talk › Pollen filter
Pollen filter
Forum Index › 206 Talk
james180
PostPosted: Fri Feb 17, 2012 10:22 am Up
Is it washable or just throw it away and buy a new one?
Im guessing this is a Peugeot part only?
Understeer is a crime.
Big_Rich180
PostPosted: Fri Feb 17, 2012 10:25 am Up
Just buy one from Euro Car parts or Opie Oils.
Pretty sure they're cheap.
PostPosted: Fri Feb 17, 2012 10:27 am Up
Throw away item, any motor factors will be able to supply you with one no need to visit a dealership
PostPosted: Fri Feb 17, 2012 10:32 am Up
Somebody actually asking about changing the pollen filter Shocked
I bet there isnt that many 206's on here that get a new pollen filter fitted at service time Laughing
PostPosted: Fri Feb 17, 2012 10:41 am Up
It's got to be the easiest thing to change on a 206. The 207 is daft because it has two pollen filters.
james180
PostPosted: Fri Feb 17, 2012 10:51 am Up
I will change everything in the next few weeks.
Got my new suspension,droplinks and brakes today so will do them first. Very Happy
PostPosted: Fri Feb 17, 2012 10:52 am Up
Changing the pollen filter on schedule means the heater blower motor has an easier life Wink
brad-morris
PostPosted: Fri Feb 17, 2012 11:48 am Up
Very true!
PostPosted: Fri Feb 17, 2012 12:05 pm Up
I changed mine,look at the dif. between the 2:
I recommend it get replaced every 10,000 Km (6200 Mile).
PostPosted: Sat Feb 18, 2012 5:18 am Up
Can you get activated-carbon pollen-filter for the 206?
Is it possible to buy some of the stuff and cut the right shape to wedge underneath a standard one?
PostPosted: Sat Feb 18, 2012 5:28 am Up
Can't see why not - www.asurafilters.com/us-usa
PostPosted: Sat Feb 18, 2012 5:35 am Up
Can't see a 206 one though..
What about this: www.ebay.com/itm/Activ...3364f17706
Would it work or waste of time?
PostPosted: Sat Feb 18, 2012 5:39 am Up
As long as it's the right size or bigger (so you can cut it down), it should work if you fit it with the normal filter I think.
It's only to stop smog really
PostPosted: Sat Feb 18, 2012 5:49 am Up
just stick the K&N panel filter on there Laughing
PostPosted: Sat Feb 18, 2012 5:50 am Up
It also stops smells and pollution.
