Latest: heikkisj
Overall: 17126
Online Now [71]:
Visitors: 70
Today: 10512
Total: 100383253
Forums › The Car › 206 Problems › Power steering heavy
banboots
PostPosted: Fri Feb 17, 2012 5:45 am Up
Does anyone have any ideas on what would cause the power steering to be heavy to turn at low speed eg. in carparks,I have been told that it is heavier than should be. It's not the wishbones as they have been replaced. What would be most likely the steering pump or the rack. The fluid is correct level, car is 14 automatic 52plate 66k on the clock. I have heard that there is some sort of pressure valve in the steering system that could have gone wrong....any ideas, thoughts? Also the steering doesn't liken to self centre which I have heard is common.
Cheers
Have a nice day!
JDave
PostPosted: Fri Feb 17, 2012 5:54 am Up
I had the exact same problem. I had a cracked steering rack, so it was leaking fluid. Was £350 to fix and that was mates rates (no labour & no tax), so was mega expensive.
Click To View My Project
banboots
PostPosted: Fri Feb 17, 2012 10:34 am Up
Did you notice any fluid leakage under the car?
Have a nice day!
marrygold75
PostPosted: Sat Feb 18, 2012 4:33 pm Up
some mate
have a nice day
