Posted: Mon Feb 20, 2012 8:35 am |
Hey guys,
While out and about last night i noticed the light which tells me my headlights/sidelights are on is no longer working :/
The mainbeam one still does though.
Im gussing the bulb has gone but surely it shudnt have.. but also that maybe a fuse has blew causing it not to show. i will add that both the sidelights and headlights are fully working still.
Now im aware that as of this year dashboard warning lights are a requirement on the MOT! so i need this sorted.
Couple of questions:
If its a bulb (i have a preplex GTI so im sure its a bulb not a LED...?) is this a case of taking off the steering wheel and getting into the dial cluster??
If its a fuse does anyone know which fuse it is? Just when i bought my car it came with a user manual from a multiplex GTI so all the fuse diagrams are different.
If someone could post up a picture of a preflex fuse box diagram that would be a huge help otherwise i will be searching all my fuses lol
Thanks guys
Karl.
Posted: Mon Feb 20, 2012 9:51 am |
It's not a fuse, it's the bulb, no need to remove steering wheel, just pull the cluster's "roof" up, and dismantle the cluster, change the bulb, easy job.
www.206info.co.uk/Foru...17669.html
three first pictures in the above link will help you.
Posted: Mon Feb 20, 2012 10:02 am |
Thanks alot for that mate
btw do you know what type of bulb i will need?
Karl.
Posted: Mon Feb 20, 2012 10:54 am |
Here you go mate, I don't leave the house without this link
206gti.net/lights/
you'll need a T05 bulb
Posted: Mon Feb 20, 2012 11:13 am |
total legend mate
