Latest: flipflap
Overall: 17140
Online Now [348]:
Visitors: 346
Members: 1
Today: 32396
Total: 113939527
Project sleeper
Go to page Previous  1, 2, 3 ... 48, 49, 50 ... 85, 86, 87  Next
PostPosted: Sun Feb 19, 2012 2:05 pm Up
I've moved onto the back end now. Rear axle has been removed and will be stripped. One torsion bar screw is seized and one end of another torsion bar is stuck. They went in with plenty of copper grease so hopefully they won't be stuck for long. Brake pipes are stuck in the calipers too!
Boot floor has had a bit of a scrub but it needs a lot more time spending on it before the underseal gets applied. Fuel tank will be removed before underseal is applied.
Matt
PostPosted: Sun Feb 19, 2012 2:48 pm Up
Trade Rating: +32
This is easily the best car on this site.
I love it. And I respect the amount of work you are putting into it.
Keep it up!
BigGreenDave
PostPosted: Mon Feb 20, 2012 2:38 am Up
MATE that is so tidy love the work and effort you have put into this and how clean it is.
fantastic job!
F**k Scene YAWN
PostPosted: Mon Feb 20, 2012 5:21 am Up
love this 206 mate, it's so clean, makes me wish I was able to make the underside of mine this clean but I use it everyday so not much point lol keep it up mate!
PostPosted: Mon Feb 20, 2012 3:04 pm Up
Decided to clean the rear calipers a bit tonight...not perfect but not finished yet. A bit of Autosol and light sandpaper on the worst parts will make them good.
Before...
After...
PostPosted: Mon Feb 20, 2012 3:32 pm Up
even my new rear caliper doesn't look as clean as yours lol
Goldin
PostPosted: Thu Feb 23, 2012 2:54 pm Up
Your's car is one of my favourite projects on this forum.
I am waiting for informations about differences betwen Eibach and H&R springs Wink
Brian
PostPosted: Thu Feb 23, 2012 3:39 pm Up
Trade Rating: +31
Paul, have a look into rust bullet before going down the epoxy mastic route. Looks great by the way! I knew this is how this project would go down the line!
BioCustoms
PostPosted: Thu Feb 23, 2012 4:37 pm Up
Bet them coils cost a bob or two Wink
PEOPLE ARE TOO SERIOUS
PostPosted: Thu Feb 23, 2012 4:39 pm Up
Decided to go for U-pol Gravitex for the underseal. Fairly cheap and can be applied with a normal schutz gun. What is rust bullet? A rust cleaner?
PostPosted: Thu Feb 23, 2012 4:52 pm Up
Won't be ordering the springs and damper for a while because there's no point in splashing out £400 for new bits that aren't going to be used. If I ordered them now I'd be eating into any warranty on the parts even without using them so I'll keep the money in my pocket for now.
Brian
Trade Rating: +31
Rust bullet is a rust preventer, but heard great things about it in the world of auld peugeots! www.rustbulletuk.com/ I've seen people use a combination of that and some form of stone chip.
Epoxy mastic got some good reviews too, but was quite a faff/messy to use from what I heard?
BioCustoms
PostPosted: Thu Feb 23, 2012 5:07 pm Up
alot of hard work here >>>> spot on mate Smile
PostPosted: Fri Feb 24, 2012 1:52 pm Up
Got my back axle dismantled today. Wasn't too difficult, just one rounded torsion bar screw which was undone with a chisel and the torsion bars were assisted with Plus Gas applied to them for a few days.
Took the trailing arms off to check the bearing which looked very healthy.
Passenger side bearing surfaces on the beam were like brand new, lightly polished but that's all.
The drivers side felt slightly notchy when rotating the trailing arms...there is a very slight wear marks on the tube. You can only just feel the marks with your finger. The other bearing surface is smooth, just the inner surface has marks about an inch long. There is no play in the trailing arm though.
So I have a few choices. I've got to bear in mind the car does 1,000 miles a year at most.
1) Reuse existing bearings and get everything painted with solid beam mounts and fit it all back together. Not worth expense of powder coating an axle which isn't 100% perfect.
2) As above but fit new bearing (not convinced this will achieve anything).
3) But new axle from Peugeot (£485!), new bearing and seals etc. Brand new so no cost for painting etc as it's won't need anything.
4) Get axle repaired at one of the axle specialists.
So far I'm tempted to just get it cleaned up and put back together with the existing parts. With such low mileage each year it should take an eternity to become an MOT failure...but then maybe I'll investigate repairing the worn side.
Lecktorious
PostPosted: Fri Feb 24, 2012 2:42 pm Up
Trade Rating: +59
I though you would want to fully rebuild the beam with new parts and paint it up, to compliment the new front springs and dampers that are being fitted?
'98 Nile Blue 306 GTi 6
Page 49 of 87
