Online Now [1216]:
Visitors: 1215
Today: 133425
Total: 150440211
Forums › The Car › 206 Problems › 206 XSI pulling to the right under power
gaz25
PostPosted: Sun Feb 19, 2012 10:51 am Up
Hi guys,
I'm new to this forum and really hoping that somebody can help, i'm at my wits end here!
My 53 plate 206 XSI pulls to the right under power, it's especially bad on the motorway and i can't push it beyond 60mph without feeling like i'm no longer in control, and taking a right hand bend is terrifying at times! I've replaced both wishbones/suspension arms and drop links which improved it slightly but the problem is still there! The car passed it's MOT on Friday with only 1 advisory regarding a bearing on the passenger side front, but surely this can't be the problem? The advisory only said slight play.
Any help or advice gratefully received!
Martind
PostPosted: Sun Feb 19, 2012 11:07 am Up
Have you had the tracking done?
gaz25
PostPosted: Sun Feb 19, 2012 1:24 pm Up
yeah the tracking has been corrected and checked twice.
gaz25
PostPosted: Mon Feb 20, 2012 4:19 pm Up
Anybody any ideas? I'm really stuck here! Sad
PostPosted: Mon Feb 20, 2012 4:23 pm Up
diff. or driveshaft?
gaz25
PostPosted: Mon Feb 20, 2012 4:28 pm Up
Thanks for the reply, How would i check for either of those?
Thank you
Jack4273
PostPosted: Tue Feb 21, 2012 3:16 am Up
That will be your engine mounts mate, mine did that same it pulled right under power then snapped back to the left when the accelerater was lifted. Jack your car up on axle stands and put it in gear with the bonnet up and see if your engine moves or bounces under throttle.
Clarion VZ409E 7 inch DVD motorised screen
Sony XMZ-R604 440 watts Channel Amplifier
Vibe Slick 12" 1200 watt Subwoofer
Pioneer TS-A6903i 6 x 9 3-way 350 watts
Raceland 4-2-1 Stainless Steel Manifold
Remapped Ecu
Wolfrace Street Hustle 17"
Very Happy
Click For Da WIP! 206info.co.uk/Garage/m...d=336.html
ARRAN
PostPosted: Tue Feb 21, 2012 7:17 am Up
Mine did exactly the same, driveshaft was f**ked Laughing If not, try wishbones.
See my project here.
gaz25
PostPosted: Tue Feb 21, 2012 8:23 am Up
Thanks for the replies guys.
Engine mounts are fine, checked driveshafts while i had it up on the stands, can't see any significant movement or hear any clicking/grinding. Wishbones are 2 weeks old, it's a head scratcher!
I read on another thread of someone having the same issue and it was down to the pinch bolts on the wishbones needing replaced, does this sound likely?
The car really doesn't seem to be liking right hand turns, whether under power or not.
Thank you
