Posted: Wed Feb 22, 2012 12:09 pm |
Just fitted some M3 rears I bought of Craig on here and they look sleek... but it looks like I wont be abel to keep them on unless I fix the issue thats cropped up from them, basically, if you look in my progress thread you will see I have a LED Brake light with side indicators, if I connect both of the new lights, one of the LED's come on permanently, which is rather odd, and the LED Reverse lights glow dimly all the time on the lights, if i keep just one of the lights on, and plug a standard ph2 in the other side, all these issues stop.
What could be causing this?
Can it be sorted?
Taaa
Jack
Poppy, My 2.0 HDI Dream  | |
Posted: Wed Feb 22, 2012 12:14 pm |
You need ti install a resistor in the loom this should stop the problem
Posted: Wed Feb 22, 2012 12:17 pm |
| Mikey2uk wrote: |
| You need ti install a resistor in the loom this should stop the problem |
Which resistor and where? Ill go get one now!!
Posted: Wed Feb 22, 2012 12:24 pm |
Posted: Wed Feb 22, 2012 12:48 pm |
Cool, ill probably get some of these, just put some halogen bulbs into the reverse for now, look minging but it fixes that issue I guess. Now, I need to get a resistor on the brake circuit ASAP, as that lights really annoying on the 3rd brake light
