Latest: Mr-Koekwaus
Overall: 17125
Online Now [104]:
Visitors: 102
Bots: 2
Today: 36776
Total: 100173569
Forums › The Car › 206 Problems › URGENT help needed> after finding a snapped bolt for EARTH
PostPosted: Thu Feb 23, 2012 10:10 am Up
As long as the main earth wire is attached to a solid metal part of the engine / gearbox & also the bodyshell it will work fine.
You need to sort that gearbox mount out!
206DAG
PostPosted: Thu Feb 23, 2012 10:23 am Up
yes to be able to get the mount fixed i need to sort the earth issue out first otherwise the car will not start will it?
PostPosted: Thu Feb 23, 2012 10:32 am Up
Nope, it will just burn the wiring loom out behind the instrument cluster Laughing
Any solid metal part of the engine / gearbox will do for the earth Wink
PostPosted: Thu Feb 23, 2012 11:51 am Up
just earth it elso where.
a lot easier
206DAG
PostPosted: Thu Feb 23, 2012 2:07 pm Up
a lot easier
It was the else that i wasn't sure about lol
anyway i found a new place for it after a little help from MrBsi.
Problem Solved
PostPosted: Thu Feb 23, 2012 2:18 pm Up
Now get that gearbox mount sorted!
206DAG
PostPosted: Thu Feb 23, 2012 2:56 pm Up
1st thing on my list for tomorrow before anything else Wink no danger there matey
PostPosted: Thu Feb 23, 2012 3:13 pm Up
70p each for the screws
206DAG
PostPosted: Thu Feb 23, 2012 6:15 pm Up
Thanks Lee, i have been trying to find the right ones but as i don't know the correct name or what they should look like i am having trouble finding any, could you point me in the right direction please, either a link or just the name so i can google search for 2 new ones
PostPosted: Fri Feb 24, 2012 2:20 am Up
Get them from Peugeot. They are 70p
206DAG
PostPosted: Fri Feb 24, 2012 6:52 am Up
what exactly do i ask for, gearbox mounting studs, bolts or screws thanks Lee
PostPosted: Fri Feb 24, 2012 11:03 am Up
Yeah just ask for the gearbox mount bolts
206DAG
PostPosted: Fri Feb 24, 2012 1:11 pm Up
Nice one thank you, will try and get down monday morning because the guy thats doing it can't fit me in until after lunch time monday, have to say though the gearbox has been secure enough since the start of August 2011 and would have thought if it was going to break loose and drop out the bottom of the car it would have done it before now, i have had hold of it and tried moving it with both hands today and there is no sign of movement what so ever so that 1 bolt thats holding it to the mount is one strong mother, it doesn't seem to be knocking and ive no strange noise when changing gear or anything so i think i will be okay to do my usual running about this weekend before he gets to take a look monday.
However i did some searching on the net this aft and found some other ideas as to how to remove the bolt, one was to remove the mounting plate and weld a nut to the bit of bolt thats left sticking out
Removing a broken bolt using a welder
and i also found this video, a great way to remove a stud using 2 nuts if there's is enough thread for the 2 nuts of course.
How to remove a stud
PostPosted: Fri Feb 24, 2012 5:02 pm Up
Both those videos are basic mechanic knowledge, i wouldnt be running your car about at all though. You'll end up with another sheared nut, and a lot of damage. If something does happen, i wouldnt come on here telling anyone.
Get the job done first, all will be well!
206DAG
PostPosted: Fri Feb 24, 2012 6:53 pm Up
Yes your right Steve, makes sense really because if it's going to happen i would bet a years salary it happen to me, and believe me it wouldn't be something i would be singing from the rooftops never mind coming on here and telling anyone Rolling Eyes
This weekend is going to feel more like a week without my wheels Sad
Page 2 of 3
