Posted: Sat Feb 25, 2012 7:50 am |
Who's out in the sun then, i'm trying to get a few things done, and while changing the gearbox oil was one of the things i wanted to do i've had to give up. It seems the drain and fill plugs on mine are square sockets and i don't have one .... I could improvise with some key steel but that could end up messy.
I could go and buy the proper socket but it seems the oil i've got from Peugeot doesn't have the filling spouts on it and i don't want to open them just incase, so even if i did get the oil out I couldn't get it back in .....
Looks like a trip to the local mechanic is in order, it'll only cost £15 and while i don't mind paying i like the satisfaction of doing things myself.
Also on todays list,
change fuel filter
inflate spare tyre - but adjust towbar first
Reseal back box and modify
Swap Steering wheel over.
| 206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out | |
Posted: Sat Feb 25, 2012 8:00 am |
Might just Hoover car out sort the clutter out in boot an give the ol gal a wash down lol then again I may just go have a few beers an watch the rugby in the pub lol
Posted: Sat Feb 25, 2012 8:09 am |
Trade Rating: +46
no but the clio yes..
Posted: Sat Feb 25, 2012 8:27 am |
I'm trying to put speakers in all around and having fun removing the whole interior at the min
Posted: Sat Feb 25, 2012 9:21 am |
yes but im stuck on how to remove rear part of interior due top belt HELP
| Breaking 2.0 hdi with ps and gti bits | |
Posted: Sat Feb 25, 2012 11:03 am |
Hi everyone 2002 206 1.4 hdi style I have removed the n/s rear brake shoes from my wifes car to replace and assembly seems much more involved than dismantling they fell apart after retaing clips and one spring removed anyone got any idea where I can find an exploded diagram she needs the car for work monday and it is not looking easy any tips welcomed thanks Chris
Posted: Sat Feb 25, 2012 11:05 am |
| deebee wrote: |
| yes but im stuck on how to remove rear part of interior due top belt HELP |
B Pillar or C Pillar.
Posted: Sat Feb 25, 2012 11:15 am |
I had three jobs to do today, clean the car which went off fine and she's shining for the first time in 2 month, and the other two jobs were remove my bumpers for colour coding the bumpstrips and fitting my alloys. Went to fit my alloys to find the garage who did my head gasket and cambelt have well and truly overtightened my drivers side front wheel... so much so that it cracked my socket on the wheel brace trying to remove it so it looks like the old girl is going to be in the garage to get them to get them off cause after 1 bent (peugeot one), and a cracked socket they haven't budged at all in fact the cars moved move more than the bolts on the wheel have..
| Now a 2010 Renault Megane Coupe owner | |
Posted: Sat Feb 25, 2012 11:26 am |
Wasn't that sunny it but no rain so I got out there and replaced my wing and headlight.
Gonna give it a good wash tomorrow.
Posted: Sat Feb 25, 2012 12:09 pm |
i have no breaks at all...,so have to check it tomorrow:(
Posted: Sat Feb 25, 2012 2:43 pm |
Changed the drop links on the 206 only to find the front drivers spring has snapped (just under a third of it has come away) so its off to the shopp tomorrow to buy spring compressors to put the lowering kit on!
Posted: Sat Feb 25, 2012 2:59 pm |
Had to get my brothers corsa on me trailer with 3 wheels onit. Didnt work and ended up nearly braking my arm and fu*cked the trailer.
Also finished taking the last few bits off the gti.
Posted: Sat Feb 25, 2012 3:25 pm |
Tom it was the ones in the middle lmao! but i got there in the end shah I've nw got gti suede door cards rather than nasty blue next upgrade is gti half suedes if anyone has a set going cheap pm me please cheers guys
Posted: Sat Feb 25, 2012 3:48 pm |
the HDi is due an oil change tomorrow, including the filter.
probably also swap front and rear wheels over.
then it's trying to track down a "clonk" .. it's only at low speed and could be the upper shock mounts ...
Plus I've got to swap out both dipped beams on the Alfa .... and finish lacquering the two repaired 206CC alloys.
Might be finished by midnight!
