Posted: Mon Feb 27, 2012 4:41 am |
Pictures will come soon but,
basically I've fitted the sub and amp.
I was wiring up then released i didn't see anywhere suitable to take leads as i didn't want them being sat on ect. so i ripped the old interior out ran the leads in and put some gti ones I've been meaning to get to good times. But i tried to go through the firewall and not one hole! i looked on here and where the grommet is behind the glove box is a plate with foam around it and i don't want to start messing with it all so I've taken it through the door hole throughout 2 grommets, then down in the arch to the headlight back round tucked between components to the battery does look nice as I've got thick wire with black tubing so its looks proffesinal no cheap looking stuff and the way I've done it you can't even see it, and I've cheeked it it gets pinch by the door which with thick isolation and black tubing it does not. GOOD TIMES just needed to get this off my chest that my model 206 does not have access like the tut on here. bedtimes!
CYA!
| Breaking 2.0 hdi with ps and gti bits | |
Posted: Mon Feb 27, 2012 4:53 am |
Trade Rating: +36
Cool story bro.
Posted: Mon Feb 27, 2012 5:08 am |
AHAHAH i had to get it off me mate shah!
Posted: Mon Feb 27, 2012 5:26 am |
Trade Rating: +32
Pretty sure you are meant to drill through the grommet in the firewall.
Posted: Mon Feb 27, 2012 7:03 am |
Suicidalsoldi3r wrote: |
Cool story bro. |
Made my day
Posted: Mon Feb 27, 2012 7:15 am |
Matt wrote: |
Pretty sure you are meant to drill through the grommet in the firewall. |
I have drilled through mine on both of the 206's I have owned. It's the best way to do it.
Posted: Mon Feb 27, 2012 2:13 pm |
jimjam19927 wrote: |
Matt wrote: |
I have drilled through mine on both of the 206's I have owned. It's the best way to do it. |
Best to cut a "x" in it so it seals against the wire.
Posted: Tue Feb 28, 2012 6:41 am |
Trade Rating: +32
Ash wrote: |
Matt wrote: |
Best to cut a "x" in it so it seals against the wire. |
That depends on how big you drill the hole
