Latest: heikkisj
Overall: 17126
Online Now [264]:
Visitors: 263
Today: 474
Total: 100373244
Forums › The Car › 206 Talk › Is it ok to do this??
fatboyslim
PostPosted: Tue Feb 28, 2012 6:40 am Up
Ok just read this on another forum...
"...these modern cars have Computers inside them, not just sensors and relays.... these computers are not much different from your Home PC or Laptop, meaning, that they can think and make choices depending on the information coming in, they then learn from it and make changes, Untill sometimes they start to get confused and jammed up...or just stuck in a never ending routine, and so nothing works untill its finished.
Like a Web Page freezing or a Sat-nav re-calculating a route-gettiing confused and crashing.
As usual its up to us Humans to Stop em in their tracks and reset them going again.
Try this 1st...
the basic reseting methods for the BSi and Body control computer,.. find internal fuse box, locate & remove the large 'SH' shunt fuse (its the comps main in feed, and the Comp' will run down and stop) WAIT 30 Minutes..... then put it back in .
shut and Lock the car, and WAIT 30 mins.... (it will do its re boot and should restore to defalutls mode) and then go to sleep..
hopefully you should now be starting back at the Factory settings for almost everything.
just re-programme the Radio channels & Clocks...... DONE....""
Is it ok to do this or not?
is it recommended by PUG?
cheers guys
Yes I own a CC and I'm neither gay or a hairdresser!!
PostPosted: Tue Feb 28, 2012 7:01 am Up
Taking fuses out with the battery still connected is a recipe for disaster on any car.
Follow the dis-connect battery procedure for pugs, which is the recomended way of resetting ECU/BSI.
www.206info.co.uk/Foru.../t=95.html
PostPosted: Tue Feb 28, 2012 11:33 am Up
are there any advantages of resetting the ecu/bsi? as long as everything is working properly? I don't see why you would do it if nothing was wrong :/
DRAPER
PostPosted: Tue Feb 28, 2012 11:35 am Up
i wouldnt do it especially owning a CC due to the roof electrics etc
206 CC 2.0 GTI SE
HAPPY AS A PUG IN MUD
Lee wrote:
Buy a new car. The 1.9D is s**t anyway.
HA love it Smile
pug206lx
PostPosted: Tue Feb 28, 2012 12:58 pm Up
I wouldn't touch big fuses like that with the battery connected.
fatboyslim
PostPosted: Tue Feb 28, 2012 1:30 pm Up
Just for the record it's not something I would personally consider doing!!
I just read it on another forum as someone was recommending it as a way to reset the BSi
craigdmjv
PostPosted: Tue Feb 28, 2012 2:50 pm Up
i have issues think its the comms2000 as my lights turn on on there own not auto lights and my indicators sometimes cancel out and i get economy mode active come up some times
