Posted: Thu Mar 01, 2012 2:11 pm |
I put up a thread a while back regarding the central locking on my gti 2000. When I press the big button on the fob the car locks then unlocks. I have taken both door mechs out and checked them and replaced a faulty boot mech. But it still wont lock, what else can I check? I have tried dissconecting each mech to see if that helps but no.
Really need to sort this as I cant go anywhere as the car wont lock.
Posted: Thu Mar 01, 2012 2:20 pm |
not sure if this will help, but at anytime have you changed the solenoids? (may be called something different lol)
but, i had a problem with my central locking, as it wouldnt always unlock when i pressed the button. so i bought a 2nd hand solenoid from another 206 but a different spec to mine, as i thought it would be the same. however, when i put it in the car would lock then unlock, like yours does.
so perhaps it's that?
dont really know what else it could be though. maybe a fuse?
| moonstone blue 206 gti 138, sp kit. completely standard | |
They won't lock unless they are all in place. So disconnecting one an then trying to lock won't work.
Have to tried to see what lock isn't going down?
Posted: Thu Mar 01, 2012 2:24 pm |
All locks go down then bounce back up.
Have checked all fuses.
Where would I find the solenoids?
Posted: Thu Mar 01, 2012 2:27 pm |
The solenoid is part of the mechanism, the ones you have already removed. (three torx screws and then remove from between doorcard and door.)
Go to a scrapyard and replace BOTH, although I doubt they will be much new from Peugeot. It will likely be the passenger side though.
Posted: Thu Mar 01, 2012 2:32 pm |
I have narrowed it down to the passenger side but it looks to work ok. I will replace the passenger side. Scrappy want £15 for 1.
Have just sold a passenger door
Posted: Thu Mar 01, 2012 2:35 pm |
yeah. but make sure if you buy new solenoids, that there the specific one for you're car. or else they wont work.
Posted: Thu Mar 01, 2012 2:46 pm |
scottsgti wrote: |
yeah. but make sure if you buy new solenoids, that there the specific one for you're car. or else they wont work. |
As long as they have the same connector then they will work.
Ricky - mine looked o work perfectly. However it didn't
How have you narrowed it down?
Posted: Thu Mar 01, 2012 2:54 pm |
A while back when it was cold the passenger door wouldnt shut for abit and it was after that the car wouldnt lock. Before this the car would lock when I was driving, but only did this once or twice. Have swopped the drivers mech.
