Latest: tc.206
Overall: 17147
Online Now [58]:
Visitors: 57
Today: 13186
Total: 116297589
Forums › The Car › 206 Problems › Help me please lol
Help me please lol
geddernley
PostPosted: Fri Mar 02, 2012 8:13 am Up
Hi just fitted new engine in my 206 it's runs ok but when try and put in Gear it just looses power and won't go !! Any ideas please help .
Ged
i dont have a clue !!!! lol
deebee
PostPosted: Fri Mar 02, 2012 9:32 am Up
Does it make any noise's act once in gear?
Breaking 2.0 hdi with ps and gti bits
Steve180
PostPosted: Fri Mar 02, 2012 11:46 am Up
If the gearbox isn't engaging properly its either the clutch release bearing, input shaft sleeve or (worst case scenario) you have a problem on the 1st line of the gearbox and the gears have de-toothed.
If it won't go in gear, have you checked to make sure the selector rods (old plastic one's tend to go) are on properly?
Peugeot do modified selectors now which are steel and have proper bushes on them to ensure correct fitment to the selector joints on the rod and box.
Check there first as you can see them when you open the bonnet (back of the engine, gearbox side, near the inlet manifold slightly further down.
2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs
geddernley
PostPosted: Fri Mar 02, 2012 1:05 pm Up
Makes no noises when in gear it moves in reverse but as soon as try and go forward it dies as if no power !!
marrygold75
PostPosted: Fri Mar 02, 2012 2:18 pm Up
have you tried setting off in other gears apart from reverse
have a nice day
PostPosted: Fri Mar 02, 2012 2:29 pm Up
geddernley
PostPosted: Fri Mar 02, 2012 2:58 pm Up
Yes tried in all other gears not just reverse !!!!!
geddernley
PostPosted: Sat Mar 03, 2012 5:23 am Up
Could it be the injector timing that's out ??
PostPosted: Sat Mar 03, 2012 5:29 am Up
What year is your car and what year was the engine from?
Did you use your old engine loom?
What engine is it?
geddernley
PostPosted: Sat Mar 03, 2012 7:55 am Up
Ye old loom and it's a 1.9 diesel
geddernley
PostPosted: Sat Mar 03, 2012 3:16 pm Up
Car is a w 2000 and engine I'm
Not sure but same model
