Online Now [34]:
Visitors: 33
Today: 2036
Total: 116614740
Forums › The Car › 206 Problems › Central Locking 0n 206sw
dave55
PostPosted: Sat Mar 03, 2012 10:31 am Up
Recently purchased a 206 sw 2002 non runner,now running after having code re-entered (not to sure what code) after diagnostic check.However the central locking is not working with key or remote fob also interior lights stay on and tail/brake lights are on.Display also shows l/h door open.Any ideas please.
PostPosted: Sat Mar 03, 2012 10:40 am Up
You have already answered your own question.
Central locking & interior light are both worked from the switch inside the door latch.
Sounds like the door latch is faulty.
If its just brake lights on all the time then stick your hand up behind the glovebox & clip the brake light switch back in to the bracket / reconnect the connector plug - common 206 problem.
dave55
PostPosted: Sat Mar 03, 2012 10:42 am Up
Thks for prompt reply would this stop complete locking system from operating?
PostPosted: Sat Mar 03, 2012 10:48 am Up
Yes as it thinks there's a door open.
Its also why the interior light is on.
You should also get a warning beep & the interior light flashing if you drive the car.
dave55
PostPosted: Sat Mar 03, 2012 10:49 am Up
Cheers off to scrappy's now. Sorry appears both front doors show open when they are actually locked would this means both locks need replacing .Brake light problem now sorted cheers
PostPosted: Sat Mar 03, 2012 10:52 am Up
Make sure you get the correct type of door latch!
Does your SW have deadlocking or just normal central locking?
dave55
PostPosted: Sat Mar 03, 2012 11:11 am Up
Not sure about deadlock is there a simple way to tell difference
PostPosted: Sat Mar 03, 2012 11:25 am Up
Peugeot Service Box & look the VIN up is the quickest way.
Whats your VIN?
OR have a look, the deadlocking type have the extra motor / lump slightly sticking out near the bottom of the unit.
Normal central locking:
www.ebay.co.uk/itm/PEU...45ff3a3d2a
Deadlocking:
www.ebay.co.uk/itm/PEU...45fa949d25
dave55
PostPosted: Sat Mar 03, 2012 11:32 am Up
Vin no :vf32ekfwf42606910 .Mr Bsi sorry to be a pain but did you notice my edit to earlier post ref both doors showing open when locked.
PostPosted: Sat Mar 03, 2012 11:43 am Up
Your VIN = 206 5 DOOR ESTATE 1.4i 75 (TU3JP) Manual gearbox 5
Your 206 has NORMAL central locking fitted.
Part number 9135 H3 for passenger door.
Part number 9136 J1 for drivers door.
Here's one:
www.ebay.co.uk/itm/GEN...27c373c54e
Heres the other one:
www.ebay.co.uk/itm/Peu...231a80beaf
Bit odd both have failed at the same time, are you sure both lock motors are connected inside the doors?
PostPosted: Sat Mar 03, 2012 11:46 am Up
The car had faulty locks back in 2003 and 2006
Faulty harness in 2003, needed new locks and keys too.
PostPosted: Sat Mar 03, 2012 11:50 am Up
Faulty locks on a multiplexed 206, never Rolling On The Floor Laughing
Mines had 2 passenger & 3 drivers side lock units fitted that I know of, I think Peugeot class them as a consumable Laughing
PostPosted: Sat Mar 03, 2012 11:53 am Up
Change them more than oil Laughing
dave55
PostPosted: Sat Mar 03, 2012 12:19 pm Up
Is there any way of testing locks to confirm this is problem before i part with some cash for replacements
PostPosted: Sat Mar 03, 2012 12:21 pm Up
Peugeot Planet - Lee's the expert on that Wink
