Latest: DanDan17
Overall: 17128
Online Now [141]:
Visitors: 140
Today: 29397
Total: 100427558
Forums › The Car › 206 Problems › Rear Stub Axle
Rear Stub Axle
kip_206
PostPosted: Sun Mar 04, 2012 5:02 am Up
Hi all car is in the garage atm and they have just quoted me 400 pounds too change my offside rear stub axle. Was wondering if anyone knew the length of one for a 1.6 99 reg or a push in the right direction. There is two on ebay but havent got a clue on the sizes i need. i asked the garage and they will not tell me as they will lose the money. Ive got a friend that will fit it for me if i can source one. Any help will be much appreciated
206 glx 1.6
PostPosted: Sun Mar 04, 2012 5:13 am Up
i got confused.
do you mean the stub pin? the length is depends on whether you got drum brake (120mm stub) or disc brake (100mm stub)
but someone need to confirmed i got the length right.
why did you need to replace them? they seldom got damaged unless your wheel hit something badly
drunknmunky
PostPosted: Sun Mar 04, 2012 5:23 am Up
Seabook wrote:
i got confused.
i curbed mine a belter and had to replace this got the part for £50 and fit myself its easy Wink
kip_206
PostPosted: Sun Mar 04, 2012 5:42 am Up
my brakes started to play up and took it into the garage to have a look and they said need new shoes and the stub axle is ruined cross thread and all sorts so guessing its the pin but dont really wanna pay 400 pounds out for something thats 50 pounds on ebay
206 glx 1.6
PostPosted: Sun Mar 04, 2012 9:43 am Up
Why can't yours be measured? You can see both ends so why not measure it?
kip_206
PostPosted: Mon Mar 05, 2012 5:49 am Up
It's still in the garage that's why been advised not to drive the car so not gonna take it away if I can't get a part Edward
206 glx 1.6
