Posted: Wed Mar 07, 2012 11:40 am |
Hi All
I have "ABS Fault/ Esp/ASP Not Functioning correctly" showing up on the head up display am i right in thinking my ABS sensor is goosed?
Very occasionaly when braking it feel's the same as when you brake on ice and you get the ABS grinding noise/feel apart from that it drive's as it should.
Thanks in advance.
Posted: Wed Mar 07, 2012 1:17 pm |
It will be the abs rings on the cv joint will have cracked happend on my 180 and was kicking in when just brakeing normally.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Wed Mar 07, 2012 1:26 pm |
Just get it code read.
If you have HID's fitted make sure the ballasts aren't near the ECU's due to the electromagnetic field.
Posted: Wed Mar 07, 2012 1:46 pm |
before paying out for have codes read just check the abs rings for cracks missing teeth i am 99% sure that's what your problem is common symptoms you will have to replace the cv joint/joints there not to expensive.
Posted: Wed Mar 07, 2012 5:21 pm |
Cheers gentlemen muchos appreciated.
Forgot to mention my car is a 206 hdi gti does the above still apply?
Also does anyone have a part number for the CV joints?
Thanks.
Posted: Thu Mar 08, 2012 12:11 am |
Yes still applys mate
Posted: Thu Mar 08, 2012 6:00 am |
Cheers mate, just got off the phone to the dealership and they claim you can't but the CV.joint alone apparently I have to but the full shaft is that correct?
Thanks.
Posted: Thu Mar 08, 2012 6:09 am |
I got just the cv joints for my 180. Ring these guys I know there nowhere near you but they will tell you I got mine off them. Manchester motor factors 0161 8700 600 and just give them your reg.
