Posted: Thu Mar 08, 2012 12:16 pm |
My left hand wing mirrors loose and i need to un-screw it to put it back and im not sure what tool i need to do this, i think its an allen key, but im not 100%, so im wondering if you could help? Thanks
Posted: Thu Mar 08, 2012 12:18 pm |
Go to your car and look!
Posted: Thu Mar 08, 2012 12:19 pm |
I have looked but i cant see the screw in the hole because of the angle, if it was as simple as looking i wouldnt be asking would i
Posted: Thu Mar 08, 2012 12:22 pm |
Look from a different angle?
Maybe a light/torch might make it a little easier?
Posted: Thu Mar 08, 2012 12:26 pm |
I may be being stupid here, but what is not to see?
Posted: Thu Mar 08, 2012 12:50 pm |
not from there, its come loose from the bit sticking out from the car
Posted: Thu Mar 08, 2012 12:53 pm |
From what I read in you original post, I was thinking "How can someone not see those screws?!"
Now I understand what you mean.
Best bet would be to take the whole mirror off so you can handle it and have a good look from all angles.
Posted: Thu Mar 08, 2012 1:27 pm |
Could be be a small torx bit like you have holding the bumpers and many other parts?
| 206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box, | |
Posted: Thu Mar 08, 2012 1:51 pm |
T20
Posted: Thu Mar 08, 2012 5:00 pm |
Will this sized one work?
Posted: Fri Mar 09, 2012 3:39 am |
mine was 3 phillips screws as to mine apart 2days ago
Posted: Fri Mar 09, 2012 3:53 am |
Changed mine last Monday. Remove the whole unit with a T20. All the other scews on the mirror unit are phillips.
