Posted: Fri Mar 09, 2012 3:36 am |
at the moment i have a momo steering wheel on car. but i know in awhile it have to have a airbag for its mot. i have the old steering wheel in the shed but the wire and bit inside the boss that sits on airbag has broke. if i put old wheel on car and clip airbag on but not connect the wires up will there be a risk of the air just going off. dont want drive to mot center and air bag goes off if i hit a pothole. any help will be great.
Posted: Fri Mar 09, 2012 3:56 am |
in your case,it would be so dangerous to do so,I recommend that you get a new one
Posted: Fri Mar 09, 2012 4:03 am |
Timon2210 wrote: |
in your case,it would be so dangerous to do so,I recommend that you get a new one |
how much is the bit where the steering wheel bolt to cost as need that aswell
Posted: Fri Mar 09, 2012 4:09 am |
Posted: Mon Mar 12, 2012 1:42 pm |
yes this is what you need to change
Posted: Mon Mar 12, 2012 2:15 pm |
I have one of them that you can have for 10gbp delivered
Posted: Mon Mar 12, 2012 2:53 pm |
Air bag needed for the MOT? Never had any problem when i swapped my steering wheel for a non airbag one.
Posted: Mon Mar 12, 2012 2:57 pm |
Bummers wrote: |
Air bag needed for the MOT? Never had any problem when i swapped my steering wheel for a non airbag one. |
MOT rules change on the 1st of April this year & a missing airbag or the warning light not going through the correct check sequence / warning lamp missing or on all the time will be an automatic FAIL.
Posted: Mon Mar 12, 2012 3:24 pm |
Trade Rating: +59
How the hell has the metal surrounding the airbag terminals gotten so rusty
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Mon Mar 12, 2012 3:34 pm |
Nope, your airbag is MULTIPLEXED
Posted: Mon Mar 12, 2012 5:50 pm |
MrBSI wrote: |
Bummers wrote: |
MOT rules change on the 1st of April this year & a missing airbag or the warning light not going through the correct check sequence / warning lamp missing or on all the time will be an automatic FAIL. |
Learn something new every day!
Am sure a friendly mot tester would turn a blind eye to a missing airbag if you can turn the warning lamp out. In fact i bet half of them wouldn't even notice it was missing
