Online Now [295]:
Visitors: 294
Today: 171770
Total: 155262348
Forums › The Car › Request a how-to › How to soundproof front doors
Scusbucked
PostPosted: Fri Mar 09, 2012 1:19 pm Reply with quote Up
Need some help with soundprofing my doors. During the winter the spikes on the wintertyres are quite loud on the motorway.
I have looked into some options, but was wondering what to do about the thin foam piece that is attached to the door. Will that need to come off? Someone told me its there mainly to absorb moisture, hence not sure whether I should lay the soundproofing coat on top of it.
Your help is much appreciated.
- Scus
WTF - Welcome To Finland Wink
138Andy
PostPosted: Fri Mar 09, 2012 1:51 pm Reply with quote Up
you can rip off the thin foam piece and pack the door with Sound Absorbing Foam (M8050)
www.swanflight.com/sou...e=googleps
you can get it there or cheaper on ebay but be sure to replace the thin foam you strip off or all you will hear is the thin bit of metal thats attached to the lock rattle Smile good luck with this Smile
Bassline_Toad
PostPosted: Fri Mar 09, 2012 3:41 pm Reply with quote Up
I used the VIBE sound deadening material (Which might be a way to go) - But for the price you pay for the VIBE stuff, you may aswell go onto eBay and buy some cheap stuff - It all does the same stuff.
2Oh!6
PostPosted: Fri Mar 09, 2012 4:01 pm Reply with quote Up
Just remove it, recommend Silent Coat for deadening.
VTEC goes BWAAAAAAH! Wink
Ash
PostPosted: Fri Mar 09, 2012 4:13 pm Reply with quote Up
Remove the foam, and replace it once you're done. Though when I did mine, I covered the door with deadening, then placed the foam on top with new glue.
Scusbucked
PostPosted: Fri Mar 09, 2012 4:26 pm Reply with quote Up
Cheers guys, ty!
- Scus
  Quick Reply
Username:
Message:
Quote the last message
