Posted: Sat Mar 10, 2012 6:37 am |
I'll keep it simple, does anyone know how to remove the drum brake cover?
Posted: Sat Mar 10, 2012 6:38 am |
Got a Haynes? Check there
If not, get one
Posted: Sat Mar 10, 2012 6:45 am |
Need to take off the hub nut, 32mm if i remember rightly?! could be wrong though. Will also need a punch and hammer to knock out the notch, then hope the bearings aren't stuck, if you have a puller, take it
Posted: Sat Mar 10, 2012 6:55 am |
You should use a NEW hub nut on reassembly & make sure you torque it up correctly!
Posted: Sat Mar 10, 2012 8:18 am |
scrappy will rip it off for you if you ask him nice
Posted: Sat Mar 10, 2012 10:25 am |
Brake drum from scrap yard i realy wouldnt bother just get a new one theyre cheap enough and youl know its not worn damaged or contaminated.
Posted: Sat Mar 10, 2012 2:54 pm |
I got full drum kit with bearings seals washer nut and drums and shoes both sides for 90 qwid off ebay 180mm drums i think the size is
| peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim | |
