Latest: DanDan17
Overall: 17128
Online Now [44]:
Visitors: 43
Today: 10285
Total: 100438002
Forums › The Car › 206 Problems › 206 gti problems
206 gti problems
Go to page Previous  1, 2
Linkpad
PostPosted: Sat Mar 10, 2012 12:32 pm Up
with what a hacksaw ?
Boo
PostPosted: Sat Mar 10, 2012 12:52 pm Up
Angle grinder
Linkpad
PostPosted: Sat Mar 10, 2012 12:57 pm Up
oh not exactly in my toolkit lol
Boo
PostPosted: Sat Mar 10, 2012 1:00 pm Up
Borrow one or go buy one from b&q there cheap enough
usher
PostPosted: Sat Mar 10, 2012 1:01 pm Up
you could drill the thread out i had to do this on my old 406 took some time
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Linkpad
PostPosted: Sun Mar 11, 2012 7:10 am Up
Second attempt with mole grips and wouldn't grip thread without it turning so no luck, got the rear brake calipers and pads off then seen a yet another torx screw holding the disc in that wouldn't budge. Whoever engineered this torx fitting needs to be shot ... Why can't they be like Ford or BMW oh i forgot its f**** peugot.
Boo
PostPosted: Sun Mar 11, 2012 9:21 am Up
Torx fittings have been around for 45 years.
Disc screw = impact driver OR if you havent got one put the torx bit in the screw head & hit it hard several times with a hammer BEFORE you attempt to undo it.
PostPosted: Sun Mar 11, 2012 10:32 am Up
A small hacksaw is perfectly adequate.
Linkpad
PostPosted: Sun Mar 11, 2012 11:49 am Up
i just remember other cars ive been on they had standard screw fittings, as for the drop links most other cars have a bolt or fixing to anchor down on the opposite end.
edward u reckon a small hacksaw would take the bolt off a drop link, i cant see that working ?
I tried hammering the torx screw on the disc, looks like an impact torx is best option. Why oh Why did i buy a 206.
Boo
PostPosted: Sun Mar 11, 2012 11:55 am Up
Genuine Peugeot drop links will have spanner flats on the threaded stud to stop the ball joint turning as you undo the nyloc nut.
PostPosted: Sun Mar 11, 2012 1:36 pm Up
You cut the nut off the droplink. Just slice a side off it.
Linkpad
PostPosted: Sun Mar 11, 2012 1:53 pm Up
aah cheers ill try that with a hacksaw, and get impact driver for the rear discs
Boo
Linkpad
PostPosted: Tue Mar 13, 2012 12:18 pm Up
3rd attempt at taking that god damn nut off the drop links this time with a hacksaw and a hammer and chisel even with 1/3 of the nut cut off and chiselling it like hell the thing still won't budge... Not sure i be able to get a nut splitter over it ...
Boo
Page 2 of 2
