Latest: dreyfalon
Overall: 17121
Online Now [507]:
Visitors: 506
Today: 101981
Total: 97401974
Forums › The Car › 206 Talk › Is there a surge protector available to protect the ECU?
Bummers
PostPosted: Sun Mar 11, 2012 2:16 pm Up
After an impulsive purchase by a relative I've been tasked with sorting out the problems of a 206 1.6 16valve xsi Crying or Very sad
It scrubbed up well which I think was why they (mother Rolling Eyes ) purchased it without it being looked over properly.
Turned out it hadn't been serviced in a ridiculously long time, the oil filter had literally disintegrated (wish I'd have took pics) and i had to fish all bits of plastic and filter out of the housing before replacing it. Obviously the oil was like tar.
I read up as much as I could find about this car and was gutted to discover they never made a haynes manual for this engine! Evil or Very Mad so if anyone knows of a workshop manual could you kindly point me in the right direction? Very Happy
So, i've found out it's fitted with a sagem coil pack, I'm hoping the ECU isn't fried because of it (idle is rough when cold - fault codes show throttle position sensor so hoping thats the cause of it).
I've read that a surge/spike protector can be fitted between the coilpack and ECU, does anyone have any more info on this at all?
Also, where is the best place to get a replacement coil pack from - is peugeot parts dept competitively priced compared to OEM suppliers or (as in the case for vauxhall which i'm most familiar with) is there a company which supplies genuine parts at fraction of dealer prices?
2003 206xsi 1.6 16valve
PostPosted: Sun Mar 11, 2012 2:20 pm Up
Peugeot for both the recall on the coil pack spike protector and for a new genuine coil pack. Think they are £63 from peugeot if i remember right.
Bummers
PostPosted: Sun Mar 11, 2012 3:14 pm Up
Recall? Will this be fitted and supplied free of charge then?
PostPosted: Sun Mar 11, 2012 3:25 pm Up
No, its about a fiver and is simple to fit yourself.
PostPosted: Sun Mar 11, 2012 4:28 pm Up
The engine is covered in the Shitroen Saxo Haynes, its the same engine as the VTS?
PostPosted: Sun Mar 11, 2012 4:29 pm Up
I beat the swearbox^^^^!!!!!!!
Bummers
PostPosted: Mon Mar 12, 2012 11:57 am Up
Phoned a dealership today to be greeted with total silence when i asked both parts & service depts about it. Neither were aware of it.
Know any dealers that do know what i'm talking about that i can get it from?
Didn't realise this was the saxslo vts engine, i'll get a haynes bought for it!
Bummers
PostPosted: Mon Mar 12, 2012 12:00 pm Up
Coilpack was £110ish inc vat, velo (vaelo? Something like that) not the elec-bourgy one that i've seen recommended. That be ok or is it worth tracking down a specific one?
PostPosted: Mon Mar 12, 2012 12:02 pm Up
Any Peugeot / Citroen main dealer part dept - part number 6555 K9 Condensor £5.29
Bummers
PostPosted: Mon Mar 12, 2012 12:12 pm Up
Ahhh perfect! Cheers for the help. I'll ring those monkeys back tomorrow and see what they have to say then Very Happy
PostPosted: Mon Mar 12, 2012 2:47 pm Up
Any more detailed info regarding this?
I remember reading about this ages ago on here, then completely forgot about it.
When is it needed and what is the procedure?
PostPosted: Mon Mar 12, 2012 2:59 pm Up
You basically splice one end in to pin 4 on the coil pack connector plug & earth the other end.
PostPosted: Mon Mar 12, 2012 3:05 pm Up
And which vehicles require the mod?
PostPosted: Mon Mar 12, 2012 3:07 pm Up
My 03 plate TU3 had it done under manufactures warranty when they replaced the coil pack.
Bummers
PostPosted: Mon Mar 12, 2012 3:44 pm Up
Just checked, it's similar but not the same (TU5JP4 in the 206, TU5J4 in the saxo)
Not sure what the differences are yet except bigger valves in the 206, still looking into it.
