Online Now [572]:
Visitors: 571
Today: 89892
Total: 105816501
Forums › The Car › 206 Problems › Peugeot 206 cutting out
Intish
PostPosted: Tue Mar 06, 2012 1:33 am Up
Hi everyone,
I not new to the forum and have consulted it many times. Its the first time i'm posting and its out of pure desperation. My peugeot 206 1.1 keeps cutting off. I've seen many peugeot owners having the same problem and I've done some search on this forum nut did not find any workable solutions:
Things i've done:
(1). Cleaned the idle control valve
(2). Changed the fuel pump
(3). Checked and cleaned all connections to ECU.
(4). Check relay under the ECU
(5). Cleaned the crankshaft position sensor
(6). Checked the spark plugs...
I'm thinking about chaging the ignition coil and spark plugs (Bosch)
If anyone have a fix for this problem please help me.....
mdstone
PostPosted: Tue Mar 06, 2012 1:51 am Up
My cutting out was always after wet weather so I'm guessing that a sensor was getting damp and giving false readings to the ECU and causing it to cut out. May not be your problem but worth a look.
Peugeot 206 GTi
marrygold75
PostPosted: Sat Mar 10, 2012 12:59 am Up
is it only cutting out on tick over,just change your plugs.
have a nice day
marrygold75
PostPosted: Sat Mar 10, 2012 1:03 am Up
it wont be wet mdstone,
not in Mauritius
have a nice day
Intish
PostPosted: Mon Mar 12, 2012 12:19 am Up
Hi,
The problem that I'm having is like that:
(1). Engine cuts off.
(2). The check engine light goes on first
(3). The other lights light up as if when u put the key to contact just before start.
(4). The i turn the key to off position.
(5). I restart the engine starts and my car runs normally.
I can drive my car normally for two days without having such problem. Then it may happen anytime.
I've done some diagnostic on several testers such as Bosch, Launch and no error reported and no fault codes. This problem is really pis... me off.
Intish
PostPosted: Fri Apr 20, 2012 9:09 am Up
Problem solved after changing the coil packs...keeping my fingers crossed.
oldskoolz
PostPosted: Fri Apr 20, 2012 8:01 pm Up
if your problem continues try changing the idle control valve rather than cleaning it, i cleaned mine many times before i gave up and bought a new one
Black 206 Gti. Soon to be 2.2
