Online Now [51]:
Visitors: 50
Today: 112014
Total: 128083462
Forums › The Car › 206 Problems › Strange noise when steering
PostPosted: Mon Mar 12, 2012 9:51 am Up
First noticed this yesterday, basically when i steer in either direction there is a loud whining sound, it's worse when the car is more stationary
I have checked the power steering fluid level which is fine, the steering itself hasn't become heavy so I am a bit stumped as to what it could be, any ideas?
Big_Rich180
PostPosted: Mon Mar 12, 2012 10:12 am Up
It sounds like the power steering pump...thats all i've got lol
PostPosted: Mon Mar 12, 2012 10:16 am Up
thats better than me mate, i had no idea at all but I guess that is the only thing it could be
rick-gti
PostPosted: Mon Mar 12, 2012 10:29 am Up
Can you here any whining coming from the pump? My old 306 pump had gone and was making a noise. Sounds like it is the pump.
clio 197sport owner
What He Said
Foz369
PostPosted: Mon Mar 12, 2012 10:52 am Up
Its probably not, but it could be the tracking. I dont really know much but my 206 made a horrible screeching noise when the tracking was out.
sig removed due to size
PostPosted: Mon Mar 12, 2012 11:22 am Up
I don't think its the tracking as mine went a while back and there was no noise
PostPosted: Mon Mar 12, 2012 11:27 am Up
Not sure where the pump is located exactly but it is coming from the front of the car and its only when i turn the steering wheel left or right
Are they cheap to have replaced?
rick-gti
PostPosted: Mon Mar 12, 2012 11:45 am Up
Its to the left of the engine and has black plastic around it and a screw cap. Ive just sold one.
clio 197sport owner
PostPosted: Mon Mar 12, 2012 11:59 am Up
Ill give you a clue.
Look under the bonnet, the cap to the reservoir for the pump has DIRECTION ASSISTANCE POWER STEERING on it & a picture of a red steering wheel Wink
Yossarian
PostPosted: Mon Mar 12, 2012 12:16 pm Up
I had mine replaced, the pump cost about £40
PostPosted: Mon Mar 12, 2012 12:18 pm Up
I know where the resevoir is just not sure on the location of the pump itself
PostPosted: Mon Mar 12, 2012 12:22 pm Up
Its attached to the resevoir.
rick-gti
PostPosted: Mon Mar 12, 2012 12:31 pm Up
Its one complete unit.
clio 197sport owner
NathanG
PostPosted: Mon Mar 12, 2012 2:28 pm Up
Its well easy to change, done mine yesterday as the steering is well heavy, took about 20 mins, 2 13mm bolts to the right as you look at it and 2 6mm allen key bolts to the left (you can get a 13mm socket on the 1 tho). You have to get these through the pulley wheel. A 17mm spanner to get the top pipe off and a pliers and screwdriver to get the clip of on the bottom pipe.
After changing mine u have decided that the steering is supposed to be heavy, actually the heaviest car i have ever driven. Oh well.
My main point is its easy.
