Online Now [3125]:
Visitors: 3125
Today: 568064
Total: 153402422
Forums › The Car › 206 Problems › ABS PROBLEM
ABS PROBLEM
frankaai
PostPosted: Thu Mar 22, 2012 4:28 am Up
Abs is kicking in when i put on full lock and brake, the light doesnt come on but you can hear and feel the abs kicking in, you know that noise and the brake pedal going like a brick, i changed my discs and pads, its doing the same thing, was maybe going to check the gaps on the abs sensors or should i just give them a good clean?
ej2_sir
PostPosted: Thu Mar 22, 2012 7:16 am Up
I'd check the abs rings for breaks/corrosion while under there.
2002 206 2.0hdi
frankaai
PostPosted: Thu Mar 22, 2012 7:38 am Up
Yeah was going to check them, hope they arent a f==ker to replace
ej2_sir
PostPosted: Thu Mar 22, 2012 9:21 am Up
No there not to bad tbh. You can either buy driveshaft complete if yours are worn or just the rings. Just carefully chisel old ones off and drift new ones on
2002 206 2.0hdi
frankaai
PostPosted: Thu Mar 22, 2012 11:39 am Up
No worries, are the drive shafts the same on all models of 206? probably a silly question.....
PostPosted: Thu Mar 22, 2012 12:59 pm Up
I think 2.0 HDi shafts are the same as the GTi. Be careful of aftermarket replacements though because they can be narrower (i.e. the shaft is thinner) than genuine Peugeot parts.
If the rings are cracked they are easy to remove.
PostPosted: Thu Mar 22, 2012 1:06 pm Up
yes, 2.0HDi shaft are same as the gti one,think 180Gti is the same too
frankaai
PostPosted: Thu Mar 22, 2012 4:59 pm Up
Cheers for the info guys
