Latest: Worthy967
Overall: 17143
Online Now [69]:
Visitors: 68
Today: 9569
Total: 114887503
Forums › The Car › 206 Talk › Changing key fob cover
frankaai
PostPosted: Fri Mar 23, 2012 4:23 am Up
Is it an easy job to change the key fob cover? i dont have to re-sync or anything like that? obviously have to get the key cut... just my old key looks s**te!!!
PostPosted: Fri Mar 23, 2012 4:24 am Up
Are you on about changing the actually key surround plastic part or converting to a flip key?
Matt
PostPosted: Fri Mar 23, 2012 4:46 am Up
Trade Rating: +32
I think either way it's pretty easy.
Just remember to swap the immo chip over too.
frankaai
PostPosted: Fri Mar 23, 2012 4:56 am Up
swapping the cover over to the flip key, was going to buy a blank cover from ebay with blank key which il have to get cut, is it easy to just swap the circuit board over?
PostPosted: Fri Mar 23, 2012 5:04 am Up
Depends what key you have?
frankaai
PostPosted: Fri Mar 23, 2012 5:09 am Up
Right ok, i thought it was going to be a straight forward swap, mine is the usual 206 key with the screw at the bottom of the front face if that means anything? its the normal two button key
JE_180
PostPosted: Fri Mar 23, 2012 5:17 am Up
Then yes it's easy, you may have to file the circuit board down a mm or so to make it fit properly as the blanks from eBay are a little hit and miss with the sizes (well mine was). But other than that it's take the immobiliser chip out of your old key, place it in the new one and then the same with the circuit board.
PostPosted: Fri Mar 23, 2012 5:18 am Up
Is it like this?
All so what flip key have you got?
shadow
PostPosted: Fri Mar 23, 2012 5:21 am Up
changed mine to a flip key fob took less than 5 mins to change over, only problem you will have is the fob will only work one way because of the position of the transponder to unlock the ignition barrel and be able to turn the key.
206cc 2.0 allure
PostPosted: Fri Mar 23, 2012 5:23 am Up
Well you must have it in the wrong place as mine works no matter which way I use it
frankaai
PostPosted: Fri Mar 23, 2012 5:25 am Up
yeah mikey mine is the same as that one
Which flip key did you get? More importantly what blade?
drunknmunky
PostPosted: Fri Mar 23, 2012 5:32 am Up
mikey seen as though your in the know about this thought i would ask is it possible to make the 206 fob fit in this casing i have one lying around and would like my key to still be a proper pug one?
cgi.ebay.co.uk/ws/eBay...0723342035
p.s sorry for hijakcing the thread
shadow
PostPosted: Fri Mar 23, 2012 5:53 am Up
i put it in the same position in the new one as in the old one, if i get time at the W/E might have a play. you got any pics where yours is situated?
206cc 2.0 allure
frankaai
i havent bought one yet this is my key
