Posted: Fri Mar 23, 2012 9:15 pm |
got my new little maxiscan obd11 code reader today anyone thinking of buying one there CRAP they,ll read a 96 yr car but don,t even look at a pug 206 i did complain to Carsets but was advised to buy a extremly more expensive job ie rip off i should have hedded advise off here, and it was posted from singapore not worth the postage
Posted: Sat Mar 24, 2012 1:24 am |
Are you sure it's the scanners' fault matey?
Which Maxiscan did you get? And what year is your 206?
Posted: Sat Mar 24, 2012 1:46 am |
V9977 wrote: |
Which Maxiscan did you get? And what year is your 206? |
Posted: Sat Mar 24, 2012 4:03 am |
That's because you didn't check the protocol of your car. That scanner is perfect for a eobd compliant car. Your car isn't eobd, hence why you need a more expensive one.
Posted: Sat Mar 24, 2012 5:30 am |
EODB is a EUROPEAN standard that came if for petrol cars from Sept 2001 and diesels from Sept 2004, Even then the likes of PSA had special electronics with the BSI that needs extra software. You might be an EODB reader to work on a Pug, but you'll only be able to read and clear the faults.
OBDII or ODB-2 is a US standard so no European car would be equipped with that unless is was sold in the US ... I've never seen a peugeot 206 when I've been out there!
Before EODB the software was up to the manufacturer and most had something hybrid meaning standard code readers may not work .. worse still some thing they do and the faults returned are incorrect or the meanings are interpreted differently.
Even if the socket for the code reader is the same ... and most are standard 16-pin ODB sockets ... they are wired up differently and the software behind the plug is different.
And a 96-year old car would have relied on a very good mechanic to diagnosed the faults ... as did cars up to about the 90s!
Posted: Sat Mar 24, 2012 7:23 am |
gazza82 wrote: |
And a 96-year old car would have relied on a very good mechanic to diagnosed the faults ... as did cars up to about the 90s! |
Depends on the protocol that the car runs whether or not a US spec scanner will work
Or if you know what each pin is, you can get the scanner to scan some ECUs if they diag via K-Line or KWP rather than ISO
Posted: Sat Mar 24, 2012 8:40 am |
My Sealey scans but it never picks up the Alfa on the k-line ... it does pick up both Pugs, the Clio but not the newest in the family .. the MiTo which will be EODB but CANBUS. Might be a newer version of CANBUS that the sealey hasn't had an update for yet.
Posted: Sat Mar 24, 2012 10:00 am |
Try L line
Posted: Sat Mar 24, 2012 11:03 am |
all i was looking for was a CHEAP little reader . these companys know they won,t work and at £25 you just sling them in the bin still a rip off and they come from outside eu so no come back i will now look at means to go back to a non ecu veh if pos ie carb ,points, etc and the 96yr old car was a year 96 build
Posted: Sat Mar 24, 2012 11:22 am |
Just file a claim. Shouldn't buy china crap in the first place really. If you are going to buy clones, get them from places like Russia and Romania
