Online Now [445]:
Visitors: 444
Today: 101884
Total: 156816988
Forums › The Car › Request a how-to › How do you remove the roof...trim?
devildriverxii
PostPosted: Sat Mar 24, 2012 2:13 pm Reply with quote Up
I had a quick look, but I'm not sure what they're called to do a proper search.
I need to remove the long black bits that go either side of the roof, and down the a pillars.
Any ideas, I don't want to just pull them off.
Also the aerial needs to come off too, that just unscrews from the inside right?
Cheers.
2002 1.6 5dr Black Edition.
ARRAN
PostPosted: Sat Mar 24, 2012 2:22 pm Reply with quote Up
EDIT: My bad, I misread your post. I'll try again Laughing
They clip in down the bottom of the wind screen, then I'm pretty sure they silde out. Smile
See my project here.
DeadEyePaul
PostPosted: Sat Mar 24, 2012 2:56 pm Reply with quote Up
I was tugging at this yesterday(I'm in a paint and spray mood)
Not sure how to unclog it at the windscreen without breaking anything but I'm interested in knowing how it's done
mattvaretto
PostPosted: Sat Apr 28, 2012 9:21 am Reply with quote Up
There's a rivet at the bottom near the bonnet that you have to pull out then they should slide out backwards. Big emphasis on SHOULD as I haven't actually done this myself!
PostPosted: Sat Apr 28, 2012 10:02 am Reply with quote Up
Two screws at the back in between boot and roof iirc.
  Quick Reply
Username:
Message:
Quote the last message
