Latest: DanDan17
Overall: 17128
Online Now [79]:
Visitors: 78
Today: 2212
Total: 100522178
Forums › The Car › 206 Problems › Best Coil Pack
Best Coil Pack
Razor34
PostPosted: Thu Mar 15, 2012 7:38 am Up
Hi,
Having a few problems with my Peugeot 206 1.4 GLX 02 Reg again where the EML is on. I have plugged a code reader in and have the P0300 code showing.
I have looked around Google and it seems to point to the coil pack needing replacing which I will probably do as well as the spark plugs but could someone tell me the best make to buy?? Different people seem to have varying opinions but I would value yours on this forum.
P.S Going to take current coil pack off if I need to to see if it is the dreaded Sagem pack or if I have NGK plugs!!!
Ray
Bummers
PostPosted: Thu Mar 15, 2012 9:02 am Up
Ha, I'm in the same boat. The bougicord ones get recommended, but I can't find any reason why - nor can I find anywhere that stocks them!
Peugeot themselves recommend valeo (sp?) and from various motorfactors I've had lots of other different brands mentioned, not one seems to have even heard of the bougicord coilpacks.
Am off today to go buy one now, may as well get the OEM one that Peugeot recommend. GSF sell it for about £78 +VAT (peugeot want £20 more).
2003 206xsi 1.6 16valve
lmilligan
PostPosted: Thu Mar 15, 2012 10:45 am Up
Go with what Peugeot recommend for te coil pack and go for bosch spark plugs, think they are the super 4 ones everyone recommends
PostPosted: Thu Mar 15, 2012 1:25 pm Up
it's not like you can choose what coil pack to fit,there is 2 brands for the coil pack,you have to fit the same as yours,because the ECU would work on that one,and might not work if you fitted the other.
But I woul say to take a look at the spark plugs first,because sometimes they cause you the EML on,they make the coil pack go faulty.
Razor34
Thanks People for the info. Will proceed with your recommendations.
Ray
Bummers
PostPosted: Thu Mar 15, 2012 5:15 pm Up
You can fit the correct coil pack for your engine - but there can be several manufacturers who all make it, hence the choice in which one to get.
Sagem ones were originally used, now I think Peugeot are using valeo. Everyone on this forum recommends the bougicord ones and from asking different motor factors they stock other different brands.
jimm
PostPosted: Thu Mar 15, 2012 8:01 pm Up
i got a bougicord from gsf
do\'nt know alot
jimm
i got a bougicord from gsf on the internet they also do valeo and bbt , 3 days ago price £78
do\'nt know alot
Bummers
PostPosted: Fri Mar 16, 2012 2:16 am Up
What engine was it for? Maybe it's just the 1.6 they don't make it for as i tried two local gsf branches and the national mail order number.
Razor34
PostPosted: Sun Mar 18, 2012 12:52 pm Up
Hi,
I am looking at buying a coil pack off a seller on ebay but I asked them the manufacturer name as obviously I do not want to get a sagem one and they have replied that they have bought it from Peugeot directly but it does not have a name on it. Surely it must be on there somewhere???
Ray
Bummers
PostPosted: Sun Mar 18, 2012 6:15 pm Up
Yes it will be. Tell them to look closer, if they are sketchy with details buy elsewhere.
Razor34
PostPosted: Sun Mar 25, 2012 5:15 am Up
Can anyone tell me what make of coilpack this is. The seller can only tell me that it says g09 on it and it is for a Peugeot 1.1/1.4 8v.
Would appreciate your help.
Ray
Alex90
PostPosted: Sun Mar 25, 2012 5:34 am Up
buy it here
www.eurocarparts.com/ignition-coil
im always buying parts from them,if you not sure you can aske them via chat window if it ll fit your car,if not you can always return it
DIESEL POWER!!!
gazza82
PostPosted: Sun Mar 25, 2012 6:40 am Up
Try carparts4less.co.uk ... it's ECP but online only and about 20% off their normal prices. Free delivery at the moment too!
