Online Now [1537]:
Visitors: 1536
Today: 24924
Total: 152070314
Forums › The Car › 206 Problems › Which Timing belt to use on 1.4 petrol?
forkhandles
PostPosted: Tue Mar 27, 2012 11:15 am Up
Hi Folks, I'm new to this forum, hoping someone can help me out. My daughters 206 1.4 Petrol GLX with A/C has a rather lumpy idle but once revved above 2000rpm is very sweet and drives really well with plenty of power. The plugs have just been replaced ( Bosch ) and the tappets adjusted. I have read there are 2 types of Timing belt, 104 or 108 teeth. If the wrong belt was fitted could this be the cause of the lumpy idle? If not, would appreciate any other suggestions as to the cure. Thanks
Fiat 127 Sport, Alfasud, Alfa 33 Gold C\'leaf, Fiat X 1/9, Alfa 164 3.0 v6, Fiat Uno, Fiat Punto, Fiat Tempra 2.0 SW, Fiat Tempra TD, Peugeot 306, Alfa 145 C\'leaf, Hyundai Tucson CRD, Citroen Saxo 1.4 Furio, Peugeot 206 1.4 GLX, Mazda MX5 1.6
Bummers
PostPosted: Tue Mar 27, 2012 1:24 pm Up
No, timing belt is not the cause here.
Is the engine managment light on?
Possible causes of lumpy idle - idle control valve, throttle position sensor, faulty MAF sensor, lamda sensor..... Or something else, lol.
First off though i'd be looking at the idle control valve, there is a guide to cleaning it on this forum.
2003 206xsi 1.6 16valve
forkhandles
PostPosted: Tue Mar 27, 2012 3:26 pm Up
Hi Thanks for the reply, the engine management light is not on, we have already replaced the idle control valve as car had been stalling and the revs were all over the place, that has now been cured.
Before the tappets were correctly adjusted, it idled alot better, with only slight unevenness although with alot of tappet noise. Could the cam lobes on the camshaft be worn? I think I read somewhere that might be an issue? Is this a common fault with the 1.4 single cam engine?
Bummers
PostPosted: Wed Mar 28, 2012 12:03 am Up
If the cam lobes were worn the valves wouldn't be operating correctly and you'd have far worse running than a dodgy idle.
Af what rpm is it idling at?
forkhandles
PostPosted: Wed Mar 28, 2012 2:02 am Up
Daughter is away in car until afternoon, so dont know the exact rpm, only to say it sounds the normal rpm. The revs do not fluctuate at idle, they remain even, just this sound as if timing is out, like misfiring, accompanied by engine lumpiness, until revved over 2000 rpm when all is fine.
Could the coil pack be causing the problem, is there any way of testing it?
Bummers
PostPosted: Wed Mar 28, 2012 12:48 pm Up
Sounds like either a fueling issue, air leak or spark problem. Could very well be the plugs/coil pack. What make are they?
