Online Now [341]:
Visitors: 340
Today: 179502
Total: 155472169
Forums › The Car › 206 Talk › Should it be?
Should it be?
Forum Index › 206 Talk
PostPosted: Fri Mar 30, 2012 12:35 pm Up
Fitted my new (second hand) icv last night but its still idling below 750, i'd say at 600 revs. Is this normal and if it's not what can i do to get the revs to where they should be?
PostPosted: Fri Mar 30, 2012 12:38 pm Up
Is it idling smooth?
PostPosted: Fri Mar 30, 2012 12:40 pm Up
It is a little when the engine first fires up but then when the revs drop it does sound like its struggling a little but everything is fine
Martind
PostPosted: Fri Mar 30, 2012 12:44 pm Up
Mine does exactly the same.
Steady idle at 600ish revs. Cleaned out everything and still no change. No Warning Lights and never stalls.
On A/C it idles closer to 900 but on ECO it always stays at 600ish
PostPosted: Fri Mar 30, 2012 12:47 pm Up
Thats exactly like mine does so it must be normal on older gti's as mine is the same year as yours Martin
Martind
PostPosted: Fri Mar 30, 2012 12:53 pm Up
Thats good to hear then, Sounds like nothing to worrie about Smile
Pugrat
PostPosted: Fri Mar 30, 2012 1:15 pm Up
il start mine up 2moz n let u both no Smile mines a 2000 Smile
Fordie 206 GTI
