Online Now [316]:
Visitors: 315
Today: 19268
Total: 157209139
Forums › The Car › 206 Problems › fitting fan loom, help removing bumper?
Kelz
PostPosted: Sun Apr 01, 2012 5:04 am Up
ok i read a few things on here about taking the bumper off and some say taking the headlamps out but others say you don't need to?
so how do you remove the bumper without taking them out? as the torx drive is under the light?
Kelz!
138Andy
PostPosted: Sun Apr 01, 2012 5:12 am Up
remove the wheel arch liner, the bumper is bolted under there
remove the headlight, its only 3 bolts Razz
should be 1 bolt either side and 3 torx screws on the front and it should pop off Smile
Kelz
PostPosted: Sun Apr 01, 2012 5:16 am Up
Ok cool will give it a go, just got the 150pc halfords professional advanced tool set for £99.99 as I had hardly any tools and this looked like it would have everything I would need lol
Kelz!
138Andy
PostPosted: Sun Apr 01, 2012 5:18 am Up
you only need a 10-13mm spanner and a 30T torx bit lol Smile
PostPosted: Sun Apr 01, 2012 6:03 am Up
If the headlamps are removed you will need to get the beam alignment checked / adjusted at your local mot garage once the car is back together.
Its just as easy to leave the headlamps in Wink
PostPosted: Sun Apr 01, 2012 6:55 am Up
If you mark the position of the headlights with tape then they should go back in the same position. If the bumper bolts are seized access if often easier from above with the headlights removed.
Kelz
PostPosted: Sun Apr 01, 2012 10:32 am Up
Well I took the lights out as it made things easier but didn't remove the bumper in the end as the wiring loom I got for the fan was actually different to the loom on my car!
The plugs were different so had to cut the loom half way and join the new loom onto it etc
Kelz!
