Latest: elelectricistadeMateo
Overall: 17127
Online Now [70]:
Visitors: 68
Members: 1
Today: 4216
Total: 100402445
Forums › The Car › 206 Problems › Gti 138 hesitant starting..
GTI_89
PostPosted: Sun Apr 01, 2012 6:16 am Up
hey guys,
wel recently my gti has been having problems starting, before it started doing this it would start instantly at the turn of the key.
right, now when i go to start it, it can take anything from 3-6seconds to fire up, somtimes it spluter abit before firing up.
it does this when the engine is cold AND hot.
at times you can smell fuel if its took a while.
the car recently had a full filter & fluid change inc plugs. The car drives perfectly, no flat spots etc.
have tried some injector/engine cleaner, stil the same.
anyone got any ideas?
a friend of mine has some OBD2 diagnostics, would this show the problem at al?
thanks.
Karl.
Im New, Go Easy On Me Very Happy
PostPosted: Sun Apr 01, 2012 6:18 am Up
You could see if any codes come up....
What plugs did you put in?
GTI_89
PostPosted: Sun Apr 01, 2012 6:44 am Up
err i THINK they wer bosch but could of been NGK. i know its one of them.
was fine until abowt 2weeks ago, was serviced 2 1/2 months ago.
PostPosted: Sun Apr 01, 2012 6:47 am Up
If it smells of fuel it could be the coolant sensor at fault. It will run rich all the time if it's knackered.
PostPosted: Sun Apr 01, 2012 6:52 am Up
If you have NGK in I would remove them the 206 does not like them
GTI_89
PostPosted: Sun Apr 01, 2012 7:04 am Up
There is a faint wiff of fuel if it takes a while to start, cant smell it any other time
GTI_89
PostPosted: Sun Apr 01, 2012 7:06 am Up
how come mate?
it runs perfectly normal once its started.
i wil double check though and replace with bosch if they are NGK, i know it had Denso plugs in when i serviced it.
PostPosted: Sun Apr 01, 2012 7:11 am Up
GTI_89 wrote:
how come mate?
Just trust us, NGK spark plugs + 206 = misfires / poor running / odd electrical faults Wink
Bosch plugs or OE Peugeot / Citroen ones only!
GTI_89
PostPosted: Sun Apr 01, 2012 7:14 am Up
oh im not arguing over them being no good was just wondering how and why they would effect it Smile
i can easily get some bosch ones and its a p**s easy job to change them.
