Latest: DanDan17
Overall: 17128
Online Now [89]:
Visitors: 88
Today: 28044
Total: 100502822
Forums › The Car › 206 Problems › Engine won't start, pure silence
bisphenol-a
PostPosted: Tue Apr 03, 2012 1:37 am Up
Recently my car was showing a slight delay between turning the key and ignition. Nothing weird except the lag. Engine sounds normal.
Today when I turned the key, the engine doesn't even turn on. I hear the click, the display lights go off(i think) but the engine doesn't crank. It's like I'm not even trying to start the car, no sound nothing.
After 5 attempts it started. Now at the mall, not sure if it will fail when I wanna go home
Sad
Don't wanna be left in the car park
DeadEyePaul
PostPosted: Tue Apr 03, 2012 1:48 am Up
When did you last get a car battery check
Adam2061994
PostPosted: Tue Apr 03, 2012 4:26 am Up
check the terminals on your battery mate, it did this on mine and i went to hell and back to find the problem, and turned out to be just that, not getting sufficient charge, i would put the key in the lights and that would come on, then id go to start it, it would click and everything would go off, that was the problem with mine anyway, hope this helps
206 1.6 owner
Ash
PostPosted: Tue Apr 03, 2012 1:38 pm Up
And check the earth on the gearbox casing hasn't come loose.
bisphenol-a
PostPosted: Sun Apr 08, 2012 8:00 am Up
oh hell, same thing acted up and I was 2 hours away from home. didn't like the idea of being stranded in the country side.
kept turning the key, i hear the "tick" but no cranking sound or any sound from engine.
my battery has a charge indicator which showed it was all charged and good. one thing i did realise was when i turn the key, every light in the car dash/display/aircon doesn't dim except the light on the electric window console switches.
desperate as i was, i just kept turning the key until it finally cranked on the 20th try? and engine roared!
went straight home, didn't stop for food.
PostPosted: Sun Apr 08, 2012 8:30 am Up
Thats why you have breakdown cover Wink
bisphenol-a
PostPosted: Thu Apr 12, 2012 12:17 am Up
I kinda figured how to start my car each time I get this problem.
I just have to keep turning the key about 15 - 20 times. Eventually the engine makes the cranking noise and starts on the first crank.
Any clue what's failing?
Andy_
PostPosted: Thu Apr 12, 2012 1:02 am Up
Could be a dodgy wire somwhere? my gfs clio has same problem
Progress Thread
spike_202
PostPosted: Thu Apr 12, 2012 5:52 am Up
It's not a dodgy wire, it's because it's a Clio haha
Could it be the starter motor as this happend to mine and that's what it was.
**spike's project**
TEAM:+200bhp
bisphenol-a
PostPosted: Thu Apr 12, 2012 10:35 pm Up
my guess was starter motor but half my guesses in the past werent always accurate.
if it is a starter motor, how much am i expecting to fork out for 1?
spike_202
PostPosted: Thu Apr 12, 2012 11:31 pm Up
Erm i think i paid £120 fitted buy a local garage.
I had same problems tho mate it seemed like the battery was constantly flat so I kept charging it only to find out it was the starter motor. If you pop to any garage they should point out what it is.
**spike's project**
TEAM:+200bhp
PostPosted: Fri Apr 13, 2012 5:33 am Up
bump start?
oldskoolz
PostPosted: Fri Apr 13, 2012 5:53 am Up
i had the same problem, turned out to be a loose connection on the battery terminal
Black 206 Gti. Soon to be 2.2
tamatisk
PostPosted: Fri Apr 13, 2012 2:32 pm Up
I had the same problem except when the engine was cold it would start straight away but if it was warm and you stopped (say for fuel) it would take about 20 goes to get it started.
Starter motor was source of problem and it cost me £126 to get a new one fitted. Could get it repaired for less but would have to wait longer.
Peugeot 206 1.4 HDI
