Online Now [271]:
Visitors: 270
Today: 172324
Total: 155465124
Forums › The Car › 206 Problems › please help me
please help me
xxkazxx
PostPosted: Wed Apr 04, 2012 9:01 am Up
I'm looking for some help with being a girl I know nothing about cars and being blonde don't help, I was told yesterday that I had a break light out took thr bulb out to change it and it was fine but still replaced the bulb but its still not working any one know if it could be a fuse and is a diffrent fuse for each side ?
dbspider
PostPosted: Wed Apr 04, 2012 9:07 am Up
have a look at the plug that goes into the light and also the pins that are on the light unit itself they may need a little cleaning up
me my car
xxkazxx
PostPosted: Wed Apr 04, 2012 9:14 am Up
I have and its all ok
138Andy
PostPosted: Wed Apr 04, 2012 9:15 am Up
dont want to sound rude but are you using lexus lights ?
they have a common problem with the bulb holders bending / no connecting properly
xxkazxx
PostPosted: Wed Apr 04, 2012 9:27 am Up
No I havnt got lexus lights lol, for some reason there's no power going to the fitting :\
craigdmjv
PostPosted: Wed Apr 04, 2012 9:35 am Up
probably corroded circuit board if you have a spare set plug them in and see if they work
138Andy
PostPosted: Wed Apr 04, 2012 9:40 am Up
just the break light or the whole light unit ? :/
try bypassing the plug with some wire Razz see if it works if it does its probably the connector
xxkazxx
PostPosted: Wed Apr 04, 2012 9:49 am Up
Its just the break light grrrr. Could it be the fuse if so where is the fuse under the bonnet or inside the car?
138Andy
PostPosted: Wed Apr 04, 2012 9:58 am Up
inside the car, cant see it being a fuse or they both would be off ?
may be a loose connection i stripped the connectors off mine and used spade connectors not had a problem since Smile
if you do this tho make sure to save your connector on the car just incase you get some nice rear lights that might work in the future Razz
xxkazxx
PostPosted: Wed Apr 04, 2012 10:15 am Up
Ok thanks :). And thanks everyone els that helped
138Andy
PostPosted: Wed Apr 04, 2012 10:18 am Up
id come do it but i dont have my wheels back yet Razz
PostPosted: Wed Apr 04, 2012 10:30 am Up
206 brake lights have 2 fuses.
For a multiplexed 206:
Right brake light is on fuse F20 - 10 amp
Left & high level brake lights are on fuse F21 - 15 amp
There MINI blade type fuses in the BSI unit.
xxkazxx
PostPosted: Wed Apr 04, 2012 11:08 am Up
Nice 1 thanks Smile
