Latest: tbafonso
Overall: 17130
Online Now [255]:
Visitors: 254
Today: 37334
Total: 103899485
Forums › The Car › 206 Problems › Help with removing lower ball joint
rick-gti
PostPosted: Thu Apr 05, 2012 10:53 am Up
Whats the easiest way to remove it? I have tried hitting it but it doesnt want to come out.
clio 197sport owner
Ste
PostPosted: Thu Apr 05, 2012 10:56 am Up
Staff - Ste
Balljoint splitter, the fork type, about £4 from halfords I think.
Or, a pry bar behind the ball joint (Behind as in looking from the wheel arch towards the engine) there's a small area that you can fit a pry bar in and push down on the wishbone and up on the hub to pop the balljoint.
Orrrrrrr, a plank of wood, with a block of wood on the end, the block of wood sits on your subframe, then the plank comes from there and out to where your wishbone is, tie it onto the wishbone with some strong rope or even better some metal chain and stand on it / put pressure on it.
Sidenote: Make sure you've fully removed the pinch bolt as it rests in a recess in the balljoint, loosening it does nothing, it needs to be fully removed Smile
The Cars:
PostPosted: Thu Apr 05, 2012 10:59 am Up
You mean pop it out of the hub???
A balljoint splitter will trash the rubber seal.
Does this help?
rick-gti
PostPosted: Thu Apr 05, 2012 11:10 am Up
Cheers steve, I have allways had problems with removing them. When I hit it its just bouncing. I will try using a bar.
clio 197sport owner
Ste
PostPosted: Thu Apr 05, 2012 11:14 am Up
Staff - Ste
Aye it'll naturally bounce back up due to the bushes pushing the wishbone upward and the suspension pushing down, it kinda wants to keep itself held together Smile once you get the balljoint split and out it'll make more sense than how it reads lol..
The Cars:
PostPosted: Thu Apr 05, 2012 12:44 pm Up
Never split one of these before but either a prybar with someone else hitting the joint with two hammers (plenty of videos on youtube) or a scissors type splitter will separate it without damaging the seal.
rick-gti
PostPosted: Thu Apr 05, 2012 1:28 pm Up
Got it split, used a bar and just kept moving it up and down. Did help by jacking the hub up slightly.
clio 197sport owner
PostPosted: Thu Apr 05, 2012 1:36 pm Up
Open up the lower joint with a chisel then pull down with a bar
