Latest: heikkisj
Overall: 17126
Online Now [56]:
Visitors: 55
Today: 6078
Total: 100378839
Forums › Tuning, Modification & Legal › Project Cars › Jamie: GTi180
Jamie: GTi180
Go to page Previous  1, 2, 3 ... 12, 13, 14 ... 43, 44, 45  Next
Jamie
PostPosted: Mon Mar 15, 2010 9:06 am Up
Yeah but Hi Spec are at the lower end of the scale and they want £850 + vat, Wilwood don't do any for my fitment, so need custom fabrication...
Got to give Compbrake a ring next!
Dave
PostPosted: Mon Mar 15, 2010 9:10 am Up
Surely you might aswell just buy some decent pads/discs instead of spending all the extra. Think sensible Wink
White Mk 5 Golf Gti
Jamie
PostPosted: Mon Mar 15, 2010 9:24 am Up
f*** thinking sensible
Jamie
PostPosted: Mon Mar 15, 2010 10:47 am Up
Does anyone know if the GTi coolant hoses will fit the GTi180?
Ie I am looking at the Samco hoses but they only list for the GTi?
Also... If I were to get some nuts & studs to replace the wheel bolts what size would I be looking at?
pretty sure it's 1.25x??
Ape
PostPosted: Mon Mar 15, 2010 10:51 am Up
Jamie wrote:
F*** thinking sensible
Good man. Sensible is boring Laughing
As for the brakes, couldn't you get some Brembo's in Pug Fitment (406 coupe or similar?) I know there's a couple of issues re spacers etc. Couldn't you have the calipers shaved a little to compensate? Maybe even some custom carriers or something?
Wilwoods are good, but you pay dearly for them!
Jamie
PostPosted: Mon Mar 15, 2010 10:54 am Up
You'd be surprised mate, Wilwoods aren't that expensive, they just don't make carriers to suit my car, so they wouldn't fit!
gti180boy
PostPosted: Mon Mar 15, 2010 11:53 am Up
they will only fit if you buy a gti radiator aswell.
because the bottom house push's inside and click in on a gti180 and on gti they just hold on buy jubilee clip.
Smile i have told you this jamie
180 Doctor
Dave
PostPosted: Mon Mar 15, 2010 11:57 am Up
But having a set of calipers with a name on them, that cost the better half of £1000 and are not needed thaaat much/not worth the money isnt exactly exciting Laughing
Wouldnt it be a better idea to see how the car does with some braided hoses, discs and pads.
Smile
White Mk 5 Golf Gti
Ape
PostPosted: Mon Mar 15, 2010 12:01 pm Up
It's not so much the name though.
The 180 discs are 283mm, my LCR ones are just over 300mm iirc.
The single piston 180 calipers are nowhere near as good as the 4pot Brembo's that are on the LCR.
I know the disc's are a little bigger on the Leon, but its a bigger, heavier car as well. The braking power of the 4 pistons is much better than the 180 single pistons. Some LCR's don't have Brembo's either, and the difference between 4 pot and single pot is alot
Jamie
Hmm, you said I might need a GTi radiator anyway didn't you Kyle?
macj
PostPosted: Mon Mar 15, 2010 1:36 pm Up
Try this Jamie
www.racecar.co.uk/gripper/
Can get a small deal on them
macj
PostPosted: Mon Mar 15, 2010 1:38 pm Up
Same as the Venair hoses. I think you need to ask
EdCherry
PostPosted: Mon Mar 15, 2010 2:08 pm Up
Wheel Studs should be 12x1.25 IIRC.
Dont go cheap on brakes, just pay the £100-150 to get the caliper brackets made up to mount something good like AP. Might want to buy a set with dust seals on the pistons too.
Jamie
PostPosted: Mon Mar 15, 2010 2:13 pm Up
Dust seals are a definite Wink
I'm not very clued up on brakes, so if I was going to go for Wilwoods, what exactly would I need, and how would I go about getting a bracket?!
Jamie
PostPosted: Mon Mar 15, 2010 2:32 pm Up
Also it seems that Compbrake offer a very good package for £750!
Page 13 of 45
