Posted: Thu Apr 05, 2012 8:32 am |
as above,is the caliper is direct swap?, i know nothing to do with abs, will i need gti disc too?
Posted: Thu Apr 05, 2012 11:07 am |
Depends which 1.6. The 1.6 16V should have indentical calipers.
Posted: Thu Apr 05, 2012 12:05 pm |
1.6 16v im using.. can use with gti 140 caliper?
Posted: Thu Apr 05, 2012 12:26 pm |
Careful though because depending on age GTi's (and XSi's) have different offsets for the discs therefore the calipers are different too.
Posted: Thu Apr 05, 2012 9:22 pm |
mine is from 1.6 16v station wagon japan spec
