Latest: sparrowdclxvi
Overall: 17139
Online Now [136]:
Visitors: 135
Today: 32623
Total: 113232573
Forums › The Car › 206 Problems › What does......
What does......
Stez
PostPosted: Fri Apr 06, 2012 5:28 am Up
A dodgy clutch release bearing sound like?
I've been getting some squeaking when the engines cold for a few months now & looking around these forums I thought it might be the auxiliary belt but I've just changed that( I also started the engine without the belt to rule out the tensioner & alternator) but its still there. I had a new cambelt & water pump fitted a couple of years ago. I've also noticed that at a standstill depressing the clutch effects the sqeal. The thing is its not a regular sqeak it comes & goes and on the odd occasion in the mornings it doesn't do it at all!
Also I'm getting a vibration rattle which I now know is the cover around the cat which is loose & can be wobbled about by hand. Does this need to be on the cat or can it be removed? I initially thought it was the heat guard on the manifold as it had corroded around one of the fixing holes but I've replaced that.
Thanx
138Andy
PostPosted: Fri Apr 06, 2012 5:43 am Up
My clutch squeaks too never though anything of it can of wd40 and copper grease sorted it right out
shadow
PostPosted: Fri Apr 06, 2012 6:41 am Up
my clutch started squeaking like yours then it was knotchy getting reverse then all gears after 500 miles it was "squealing like a pig" get it sorted before anymore damage is done.
206cc 2.0 allure
MrZiggerz
PostPosted: Fri Apr 06, 2012 7:00 am Up
If you push the clutch in and it goes away, there's your problem.
138Andy
PostPosted: Fri Apr 06, 2012 7:05 am Up
ahh , push the clutch in and it goes when you rev it squeals ?
its your fan belt
gaffa786
PostPosted: Fri Apr 06, 2012 7:06 am Up
Or when you release the clutch slowly it makes a loud squeek what would that be
