Latest: tbafonso
Overall: 17130
Online Now [238]:
Visitors: 237
Today: 50017
Total: 104631760
Forums › The Car › 206 Problems › 206 -00 Celing lights won't light
Rpbh
PostPosted: Fri Apr 06, 2012 9:27 am Up
Trouble with ceiling light inside.
They will not turn on when I open a door or turn off the car as it should. The switch on the ceiling is set for them to do so, but it does not help. The lights do work for when I change the switch so that they will be constantly on, they do. Have checked the fuse and it's not blown.
The question is: How do I get the lights to turn on when I open the doors or turn off the car? Perhaps it is wrong with the switch?
Many thanks for all your help!
Dare to be stupid
gaffa786
PostPosted: Fri Apr 06, 2012 9:30 am Up
did you try taking the bulb out before? mine did this when i took the bulb out to replace it. but after i put it back on properly it started working how it should. make sure the connectors are clean when its taken off
138Andy
PostPosted: Fri Apr 06, 2012 10:12 am Up
I agree! What He Said 206info.co.uk
Rob.Be
PostPosted: Fri Apr 06, 2012 10:33 am Up
considering he posted a couple hours about a central locking problem, guessing the immobiliser or the fusebox, disconnect car batter (search proper procedure for it on forum) and check your fuses inside at the steering wheel and under the bonnet, then reconnect the battery if nothign found and maybe in that time the immobiliser might come to its senses Smile
206 1.4Hdi
Rpbh
PostPosted: Fri Apr 06, 2012 11:48 am Up
Thanks again Rob.Be!
I'll try that and hope it "comes to it's senses"! =D
Dare to be stupid
