Latest: Andyblue64
Overall: 17123
Online Now [303]:
Visitors: 302
Today: 79700
Total: 98351254
Forums › The Car › 206 Talk › Smoked Side Repeaters
mattvaretto
PostPosted: Sat Apr 07, 2012 4:58 am Up
Ok so I bought smoked side repeaters like these from ebay (only difference being they were smoked ones.) www.ebay.co.uk/itm/PEU...231528bbbf
When I've taken the old ones off they have the white connection on the bottom like this.
www.ebay.co.uk/itm/SID...56482613c2
I can't work out how you fit the new ones to the connection as the lense bulb and connection are 1 part that you can't take apart.
Any help would be greatly appreciated!
PostPosted: Sat Apr 07, 2012 5:07 am Up
that is very odd mate because the side repeaters come as in the 1st link and when you remove the factory repeaters you just twist them which releases the wiring attached to the bulb holder
PostPosted: Sat Apr 07, 2012 5:11 am Up
The newer side repeaters they crystal ones are a sealed unit and you can not remove the bulb holder from them.
What are your original repeaters?
mattvaretto
PostPosted: Sat Apr 07, 2012 5:20 am Up
Sorry should have said that it's from an '05 206. When I removed the originals it was the lense, bulb then the grey and white part like in the second link but it was all one part and I couldn't remove it.
PostPosted: Sat Apr 07, 2012 6:07 am Up
Yeah you cant remove it as its a sealed unit.
You will need to ask and see if someone has the older type with a bulb holder that the want to swap.
mattvaretto
PostPosted: Sat Apr 07, 2012 6:09 am Up
Ah right will get looking thanks for that Smile
PostPosted: Sat Apr 07, 2012 10:30 am Up
The bulb holders for the older type side repeaters are £3.29 each new from any Peugeot / Citroen main dealer.
mattvaretto
PostPosted: Sat Apr 07, 2012 11:53 am Up
Ah right that's cheaper than ebay. Is there a part number?
