Posted: Sun Apr 08, 2012 9:01 am |
Every now and again when ever I start the car the engine sorta goes batshit crazy and trys to shake its way out of the car it calms down after it gets 2-3 minutes of high revs ?? When the engines shaking its really going for it and shaking the whole car ? Any ideas what this could be ?? It don't always happen that's why I'm having problems discribing it to the garage probably once or twice a month
Posted: Sun Apr 08, 2012 9:02 am |
2.0GTI 138 2003
Posted: Sun Apr 08, 2012 11:39 am |
common problem on all Gtis and GTi 180.
What spark plugs have you got in it?
Normally down to using NGK spark plugs, bad coilpack or even the hydraulic tappets.
Posted: Sun Apr 08, 2012 11:40 am |
Engine mounts? Are the drive shafts spinning straight? Have you hit a pot hole or curb recently?
Posted: Sun Apr 08, 2012 1:58 pm |
i did put it through a fence but thought i fixed everything
Posted: Sun Apr 08, 2012 3:19 pm |
Could it of been possible that something under the car / engine bay was caught buy something just a thought, maybe take it to a garage and have a look underneath to see if all is well, it's funny how you say it only happens now and agen as a bent shaft or similar would be all the time and you'd know about it.
Posted: Mon Apr 09, 2012 11:52 am |
138Andy wrote: |
i did put it through a fence but thought i fixed everything |
Have a read of what I posted, both 206 Gtis I have owned have done the same at some point in my ownership, and if you do a search you will see that it is a common problem on the 138 gti.
