Latest: heikkisj
Overall: 17126
Online Now [440]:
Visitors: 439
Today: 22908
Total: 100355869
Forums › The Car › 206 Problems › 206 2ltr HDI (Turbo) Engine Shake - Juddering
ArmouredGoat
PostPosted: Sun Apr 08, 2012 2:55 pm Up
Hi have read through the forums but not seem to have anyone who has had the same issues that I am experiencing, basically it started yesterday and before this was driving sound.
i have two issues which started at the same time, the starter motor is making a screeching noise when started, i believe this down to the solenoid not being lined up, when the car starts is when I have my main concerns
The engine is juddering, like its misfiring and the whole engine is shaking in neutral, once in gear its fine or the clutch pedal is pressed but the engine is still juddering.
Last week it had a service new oil, and filters anyone got any idea's thanks in advance.
Live and learn
ArmouredGoat
PostPosted: Sun Apr 08, 2012 3:23 pm Up
Also the car is not smoking...and the head is fine..
Live and learn
ArmouredGoat
PostPosted: Sun Apr 08, 2012 3:57 pm Up
Further to this, battery has full charge and is not dropping under load.
Glow plugs seem fine.
Live and learn
gaffa786
PostPosted: Sun Apr 08, 2012 4:06 pm Up
what spark plugs are you using
you need to be using bosch super 4's i think (not sure but maybe someone can confirm)
PostPosted: Sun Apr 08, 2012 4:23 pm Up
diesel don't have spark plug.
is the idle rev stable at 800rpm?
gaffa786
PostPosted: Sun Apr 08, 2012 4:25 pm Up
o lol sorry did not even read the title properly
ArmouredGoat
PostPosted: Sun Apr 08, 2012 4:57 pm Up
is the idle rev stable at 800rpm? No
Live and learn
PostPosted: Sun Apr 08, 2012 5:02 pm Up
better to get a live reading to narrow down the problem.
but i would think is fuel related issue, could be injector/ wire harness
ArmouredGoat
PostPosted: Sun Apr 08, 2012 5:13 pm Up
Ive had a fiddle about underneath and the problem seemed to be related to the air filter, but the clutch is also juddering, this goes away when pressed in...
Live and learn
ArmouredGoat
PostPosted: Sun Apr 08, 2012 5:14 pm Up
Its no longer juddering as it was before (engine), its just the clutch..
Live and learn
