Posted: Sun Apr 08, 2012 4:14 pm |
Hi does any one now how i can fix water leaking from the metal pipe in my peugeot? It appears to be a pin p***k but is in an awkward place. Any advice welcome please.
Posted: Sun Apr 08, 2012 4:20 pm |
Posted: Sun Apr 08, 2012 4:35 pm |
Many thanks, will get some tomorrow hopefully motorist shop down road will sell it, as desperately need car for tuesday. Thankyou.
Posted: Sun Apr 08, 2012 4:44 pm |
would you happen to know what the pipe is called....its the metal pipe that runs around the side of the cylinder head that also feeds the heater pipe...and where can you get them....many thanks
Posted: Sun Apr 08, 2012 4:46 pm |
Lia0511 wrote: |
Many thanks, will get some tomorrow hopefully motorist shop down road will sell it, as desperately need car for tuesday. Thankyou. |
If you have an halfords nearby they sell it
Posted: Sun Apr 08, 2012 4:48 pm |
will it work on hot pipe as this pipe has hot water running through it just need it to last till get a new one
Lia0511 wrote: |
would you happen to know what the pipe is called....its the metal pipe that runs around the side of the cylinder head that also feeds the heater pipe...and where can you get them....many thanks |
Your best bet is to go to the dealer or your local scrappy
Posted: Sun Apr 08, 2012 4:49 pm |
Lia0511 wrote: |
will it work on hot pipe as this pipe has hot water running through it  |
"Resistant To High Temperatures: QuikSteel maintains its qualities when exposed to temperatures in excess of 260°C (+500°F)."
Thats in the add from the link
Posted: Sun Apr 08, 2012 4:52 pm |
many thanks and much appreciated...why do cars always go wrong on bank hols....lol
Posted: Mon Apr 09, 2012 12:48 am |
I'd just go to the dealer and buy a new one. Might be slightly tricky to fit so if you aren't that great with spanners then get somebody competent to do it.
Any other fix is a temporary bodge.
Posted: Mon Apr 09, 2012 2:09 am |
Lia0511 wrote: |
just need it to last till get a new one |
Temporary bodge is just what was asked for.
Not as if that stuff is a bodge. It is very good stuff and that is what it was designed to do. When I was on patrol with the AA, we always carried it on board.
Posted: Mon Apr 09, 2012 3:07 am |
Edward wrote: |
Any other fix is a temporary bodge. |
Add in the possibilty that when the bodge fails it could also take head gasket with it
Posted: Mon Apr 09, 2012 12:33 pm |
Thanks MartinD, used what you suggested and have been out in the car today, with no problems. Thankyou.
Posted: Mon Apr 09, 2012 2:07 pm |
Glad I could help you.
As you are no longer leaking water, you should be A-OK.
