Latest: DanDan17
Overall: 17128
Online Now [57]:
Visitors: 56
Today: 10628
Total: 100530575
Forums › The Car › 206 Problems › my steering wheel changes my revs
SamWhitmarsh
PostPosted: Mon Apr 09, 2012 10:34 am Up
its not really a problem but when i move my steering wheel to the left or right it revs my car a tiny bit. its just abit annoying would like to know what is making it do that?
Ste
PostPosted: Mon Apr 09, 2012 10:37 am Up
Staff - Ste
I guess this is while your at idle? If so this is normal, it's the steering pump.
The Cars:
jayz206gti
PostPosted: Mon Apr 09, 2012 10:38 am Up
I take it you mean 'turning the wheel when your stationary?' If so its the power steering pump being powered and is normal. Although you should try not to steer the car if your not moving as it puts stress on the pump.
Upgraded from 138 to 180
00budham00
PostPosted: Mon Apr 09, 2012 10:48 am Up
That's normal as alternator is working hard er because of steering pump
PostPosted: Mon Apr 09, 2012 11:54 am Up
A/C will do it as well.
SamWhitmarsh
PostPosted: Mon Apr 09, 2012 12:01 pm Up
thanks guys just thought it was something bad.
Sam Whitmarsh
PostPosted: Mon Apr 09, 2012 3:37 pm Up
Seeing as the power steering system is fully hydraulic on all 206's apart from the FAPTASTIC 1.6 HDI the alternator has nothing to do with raising the idle speed due to power steering movement.
The power steering system pressure sensor sending a signal to the engine ecu is what raises the engine idle speed.
Only thing the alternator & power steering pump share is the drive belt.
138Andy
PostPosted: Mon Apr 09, 2012 4:49 pm Up
mine does it as well its normal
