Online Now [38]:
Visitors: 37
Today: 1218
Total: 116613925
Forums › The Car › 206 Problems › Rattling noises driving me nuts!!!
Razor34
PostPosted: Tue Apr 10, 2012 2:19 am Up
Hi,
Got a really annoying rattle and it is driving me nuts. The car is a Peugeot 206 1.4 GLX 02 Plate.
Basically when I start up the car and drive there is a rattle from the front but it is only intermittent and goes away mostly when the car warms up. The exhaust is all sound from the CAT back and clamps are in place. The aux belt and tensioner spring have been replaced also so I know it is not that.
Can somebody help as it is really peeing me off!!!!
Ray
Razor34
PostPosted: Tue Apr 10, 2012 2:50 am Up
Additional the noise is not there if I am accelerating!!!
Ray
Ash
PostPosted: Tue Apr 10, 2012 3:23 am Up
Check the exhaust manifold shielding.
I *think* that is the one that normally causes people problems.
Razor34
PostPosted: Tue Apr 10, 2012 3:30 am Up
Cheers Ash. Is it easy to get access to?
Ray
Ash
PostPosted: Tue Apr 10, 2012 4:42 am Up
Yeah, you can see it when you open the bonnet.
It gets very hot with the engine on so don't touch it unless the engine hasn't been used.
That is usually the main culprit.
Razor34
PostPosted: Tue Apr 10, 2012 5:01 am Up
Thanks, will give it a go and keep you posted!!!
Ray
gazza82
PostPosted: Tue Apr 10, 2012 6:46 am Up
Check the crank pulley as well ...
Razor34
PostPosted: Tue Apr 10, 2012 7:15 am Up
Mine is a petrol, thought crank shaft pulley was problem on HDI's???
Ray
shadow
PostPosted: Tue Apr 10, 2012 8:35 am Up
could be broken engine cover clips
206cc 2.0 allure
Razor34
Hi Shadow,
Is this quite common and are they easy to replace?
Ray
shadow
PostPosted: Tue Apr 10, 2012 8:51 am Up
they are plastic slot clips (push and twist to lock/unlock) so very easy to break cost pence from a main dealer.
206cc 2.0 allure
PostPosted: Tue Apr 10, 2012 9:16 am Up
Not on a TU3 engine it wont be as it hasnt even got an engine cover fitted.
Razor34
PostPosted: Tue Apr 10, 2012 9:24 am Up
Cheers MrBSI was hoping you would reply.
Ray
Ash
PostPosted: Tue Apr 10, 2012 10:10 am Up
I\'m with stupid!
Razor34
PostPosted: Fri May 04, 2012 8:04 am Up
Still got this problem, not heatshield. Anyone else?
Ray
