Online Now [361]:
Visitors: 360
Today: 132099
Total: 155087242
Forums › The Car › 206 Problems › heater, aircon and engine cooling fan not working
sutron86
PostPosted: Tue Apr 10, 2012 12:48 pm Up
hi bought a 206 xsi and the heater dosent work, no noise fron fan or anything. also the air con light dosent come on when button is depressed. then the other day i too it for an mot and the mechanic said the engine cooling fan dosent come on. are these connected and any ideas?????
206 xsi
PostPosted: Tue Apr 10, 2012 12:51 pm Up
Fuse?
sutron86
PostPosted: Tue Apr 10, 2012 12:57 pm Up
nah not the fuses, checked all of those under the bonnet and drivers side in the car
206 xsi
PostPosted: Tue Apr 10, 2012 2:34 pm Up
the relay of the fans maybe faulty,and how is the car temp.??is't working well,does it reach 90?
sutron86
PostPosted: Tue Apr 10, 2012 3:30 pm Up
yeh the car gets up to temp fine. any idea where the relays for the heater are located?
206 xsi
PostPosted: Wed Apr 11, 2012 11:45 am Up
Its the relays at the front of the car, if the vehicle has aircon which i suspect it will
The earth wire will have fully corroded, just buy a new loom section from peugeot
PostPosted: Sat Apr 14, 2012 12:00 pm Up
