Latest: morgan20
Overall: 17135
Online Now [297]:
Visitors: 296
Today: 128434
Total: 110680157
Forums › The Car › 206 Problems › ABS Light keeps coming on and off
frankaai
PostPosted: Wed Apr 11, 2012 2:28 am Up
ABS Light keeps coming on and off randomly, i replaced the abs ring with this
www.ebay.co.uk/itm/170...1439.l2649
it was on done on thursday, now the light comes on around 30 mph each time i use the car, i think there might be a noise coming from either the bearing or the new abs ring as i suspect it might be rubbing the sensor, does anyone know from that ebay link if that is the right abs ring for the 2.0 hdi? im sure they are 90mm
Big_Rich180
PostPosted: Wed Apr 11, 2012 2:44 am Up
It could be the sensor thats on the way out too or the ring has beem fitted badly.
Im not sure what the inner diameter should be but did you check there was enough teeth on the ring?
frankaai
PostPosted: Wed Apr 11, 2012 3:24 am Up
yeah il get one of the lads in here to count the teeth later, might just end up getting a second hand shaft
Big_Rich180
PostPosted: Wed Apr 11, 2012 3:29 am Up
I think the ABS rings come on the CV joint, well they do on the 180 anyway.
That maybe a better option but I would recomend you get the codes read on it first because it could end up being a different ring/sensor or even a break in the wire....like my 180 had.
PostPosted: Wed Apr 11, 2012 3:43 am Up
Count the teeth on the other driveshaft that hasnt been touched & see if the new ABS ring has the same amount of teeth.
frankaai
PostPosted: Wed Apr 11, 2012 4:53 am Up
yeah il get the codes checked later and see what they say, plus il count the teeth too, cheers
