Online Now [349]:
Visitors: 348
Today: 162870
Total: 155455825
Forums › The Car › 206 Problems › [solved] Battery light!! One problem after another :(
Jensen
PostPosted: Fri Apr 13, 2012 7:25 am Up
Well I've just changed my alternator as it wasn't g my battery, now my battery light comes on when I rev my car? Any ideas what the problem could be
PostPosted: Fri Apr 13, 2012 7:35 am Up
Is it only coming on since its had the alternator put on? If so could be a loose connection on one of the wires.
Jensen
PostPosted: Fri Apr 13, 2012 7:43 am Up
Ye it wasn't on before, apparently it's charging the battery fine and all that, so maybe an earth strap or something?
Abzynthe
PostPosted: Fri Apr 13, 2012 7:52 am Up
East Area Rep - Abzynthe
I was going to suggest the belt might be loose, but if its still charging the battwery then it might not be.
Jensen
PostPosted: Fri Apr 13, 2012 8:27 am Up
I was thinking that but there's no squeezing or anything, only other thing I can think of is the bushes in the alternator are shot but I hope it's not that Sad
Jensen
PostPosted: Fri Apr 13, 2012 9:22 am Up
Seems like I've found the problem! My so called 'new' alternator seem not to work -.- getting a reading of 12.25 when the car is of and 11.75 when it's on, in guessing that's why the battery light comes on when it goes above 4500rpm because it's dragging to much power, joys! Looks like I need a new alternator Sad again!
jimjam19927
PostPosted: Fri Apr 13, 2012 10:58 am Up
take it back to whoever fitted the alternator then or did you buy a second hand or something?
Member: 685
I Over Use Smilies Razz
Jensen
PostPosted: Fri Apr 13, 2012 11:44 am Up
was one from scrappy mate, they retail at stupid money, it is going back to him though
PostPosted: Fri Apr 13, 2012 3:41 pm Up
Get a service / exchange unit from your local motor factor Wink
