Online Now [560]:
Visitors: 559
Today: 138524
Total: 156853329
Forums › The Car › 206 Talk › wipers auto function to 10sec/intermitant can it be done
Forum Index › 206 Talk
usher
PostPosted: Fri Apr 13, 2012 12:58 pm Up
basically my wipers in auto are unreliable it can be spitting slightly and they wil run fast and vise versa
is it posible to change the stalk to an intermitant stalk or would i need to change parts of the loom ie not worth while
2000 reg gti
thanks
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
00budham00
PostPosted: Fri Apr 13, 2012 1:11 pm Up
they have a mind of there own :S
spike_202
PostPosted: Fri Apr 13, 2012 1:23 pm Up
I would say maybe change the relay if it can be done?
**spike's project**
TEAM:+200bhp
PostPosted: Fri Apr 13, 2012 1:58 pm Up
This is how they work! Mines a 54 plate and can be going like mad when spitting, and nothing at all when its peeing down! I think someone posted a how to on reseting it.
PostPosted: Fri Apr 13, 2012 3:30 pm Up
2000 reg gti
thanks
Yours is the Bosch system as its non plexed, unclip the mirror cover, carefully unclip the sensor ( 1 clip each end ) & you will find 2 clear gel pads stuck to the sensor - these need to be sitting tight / sandwiched between the sensor & screen else the system doesnt work correctly.
I've no idea where you would get replacement gel pads from.
I wonder if the windscreen boys ever bother to replace them or just stick them back on when they change a screen Laughing
usher
PostPosted: Mon Apr 16, 2012 1:50 pm Up
tanks for the replys i will gave it a go mrbsi
shame pug couldnt have made it a better system as i had the same problem with my last car
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Tue Apr 17, 2012 9:44 am Up
Blame Bosch as they designed it.
