Latest: Andyblue64
Overall: 17123
Online Now [311]:
Visitors: 310
Today: 25703
Total: 97973025
Forums › The Car › 206 Problems › fuel gauge at 1/4 & tank empty
boombastik
PostPosted: Fri Apr 13, 2012 12:48 pm Up
Hi folks
My sons 206 broke down the other night after a bit of trouble shooting today i found the tank to be empty but the gauge reading 1/4
had the sender out and moved the float but it made no difference, even with the sender unit disconnected it still reads a 1/4 tank
any one got any ideas? is it the gauge ?
Boombastik
Abzynthe
PostPosted: Fri Apr 13, 2012 12:50 pm Up
East Area Rep - Abzynthe
have you tried taking the needle off and moving it so it shows empty? You could then put fuel in it and see if it moves up to where it should be.
Cheap fix if it works Wink
PostPosted: Fri Apr 13, 2012 12:58 pm Up
BSI needs updating
boombastik
PostPosted: Fri Apr 13, 2012 12:59 pm Up
put £20 in it after we discovered it was dry and the needle never moved
is it a task getting the instrument cluster out then ?
Boombastik
jimjam19927
PostPosted: Fri Apr 13, 2012 1:17 pm Up
not at all.
I would fill the tank up to the max then put the needle in at the max line. Its the easiest way for a fix and is pretty acurate
Member: 685
I Over Use Smilies Razz
boombastik
PostPosted: Fri Apr 13, 2012 1:19 pm Up
cant understand why that would work if the gauge isnt working ????
just tried a BSI reset and thats made no difference either
Boombastik
Matt
PostPosted: Fri Apr 13, 2012 1:22 pm Up
Trade Rating: +32
Have you put more petrol in since?
boombastik
PostPosted: Fri Apr 13, 2012 1:24 pm Up
good point, no we havent however as mentioned earlier the gauge would read 1/4 tank with the sender unit out and un plugged
Boombastik
PostPosted: Fri Apr 13, 2012 1:34 pm Up
Just ignore me. Told you the answer as to why it does it, but hey...
boombastik
PostPosted: Fri Apr 13, 2012 1:53 pm Up
so you going to tell how to update it then
Boombastik
PostPosted: Fri Apr 13, 2012 2:14 pm Up
Take it to Peugeot
boombastik
PostPosted: Fri Apr 13, 2012 2:21 pm Up
ah ok, we dont have a pug dealer in aberdeen any more
Boombastik
PostPosted: Fri Apr 13, 2012 2:23 pm Up
You do, it's Belmont in Kemnay
boombastik
PostPosted: Fri Apr 13, 2012 2:24 pm Up
ah ok, never knew they were out there, thanks for the info... any idea of the cost then?
Boombastik
PostPosted: Fri Apr 13, 2012 3:32 pm Up
£60-80
